Why do I need a twin stick?
walker_creek
If you have a j-shift Dana 20, you'll be able to shift with little more than fingertip pressure.
Plus, a twin stick gives you the options of front wheel drive only and 2wd
Low range. Probably one of the best modifications for the dollar.
ScanmanSteven
I have a J shift and just put in twin sticks. The advantage is it now shifts easier because I'm only shifting the front or rear, not both at the same time. If you off road, there are times when you might only want low rear or low front with the other in neutral. Being a gear driven transfer case, binding is common but the twin stick takes care of that.
brandenpro
Salem, OR
Its fairly inexpensive, and easy to do with J shift. Not much harder with T.
You will actually be able to shift in and out of 4wd. Not to mention the flexibility. Limping out of the woods in front wheel drive alone 1 time will make you glad you did it.
jw0747
San Antonio, TX
no disadvantages that I can see other than installation. shifting the transfer case is far easier than wrestling with my old J-shifter. never had a T-shifter. advantage is that you can control both front and rear drives separately; one stick controls front drive and other stick controls rear drive. if your rear axle drive fails you can shift it into neutral and drive with the front axle which you can't do with either a J- or T-shifter.
miikee73
Shadetree Guru
Aloha
I flat tow mine (remove rear driveshaft) and when I want to unhook I don't have to put the driveshaft in to drive it. And face it,there is a COOL factor to having all them shifters.
BRONCOBERT
X3 on the col factor! The only disadvantage would be that it could be shifted into front low and rear high at the same time.
The J-shift has more advantages. Mainly it gets rid of the wear prone stock shifter and can fix some of the issues that it causes when it wears.
T-shift there isn't that much advantage (other then replacing a part that has wear), that is until you get into the transfer case and work over the pills and rails. T-shift you have the exact same options in original and twin stick, just a different way to get to them. To some it is more confusing, others it is simpler. How can it be more confusing? You have to shift the levers in the right sequence. You can't shift the rear into nuetral until the front is in nuetral first. You can't shift the front into gear until the rear is in that range first. Same logic as stock. That is until you play with the rods and pills
broncnaz
Maybe the only other possible disadvantage beside the confusion is you see a lot of guys with twin sticks that need bungy cords to hold them in gear. Of course thats fixable just seems to be a common issue.
Viperwolf1
electron whisperer
That's because of a problem with the tcase not the shifter.
broncnaz
I understand that and never said it did. just see many do the conversion then have to run bungy cords to keep them in gear. Sometimes theres more to the conversion than people let on or actually do.
matts460
Well i was considering doing the twin stick conversion but... my J shifter is working just fine and is no problem at all to shift from high/low or low/high or back and forth from 2/4 when out playing. I understand the pros to the conversion but sofar havent really needed it. I figure the best pro is 2low in rear but jee if i really want that i can just not lock in the hubs i guess. Oh ya plus chicks dig guys with twin sticks HEHE right? lol
blubuckaroo
Grease Monkey
Ridgefield WA
I was perfectly happy with the stock "J" shifter but had to do the twin stick when I did the NV3550 mod. I actually like the way twin sticks link to the shift rails on the "T" more than the "J" transfer case. The "T" actually has little heim joints where the "J" shifter slides in slots.
bronconut73
For me the advantage of the twin sticks was I can actually get the damn T-case in and out of gear. I fought that stupid wobbly J-shifter for years. I couldn't wait to install twin sticks and off road more because of them.
markperry
The advantage for me was when my CV joint/rear driveshaft shot craps. I just locked the hubs and drove for a week on the fronts until my new driveshaft came in.
