Window frame to windshield gap
Yooper74
Bronco's at paint. Paint guy did a great job with the doors. Gaps are all very nice, alignment is good, body line is good, etc
only issue is drivers side windshield frame to door window frame gap is huge. Passenger side is not. We suspect the replacement drivers side A-pillar was installed improperly causing the window frame to be further away than it should be.
Its kind of to late to reverse course and tear all of that apart so we are considering moving the window frame forward on the door a fraction of an inch to shrink that gap. I'm going to run a soft top so the fraction of an inch should be cheatable on the back side of the window frame.
Has anyone ever done this?
Here's a couple pictures. The windshiield frame bolts are not in so it would pinch down some
TXDraht
Would adding the turnbuckle attachments that attach window to roll bar and just tweak that side a little tighter to close the gap accomplish the same thing?
Y
Yooper74
To some degree yes. It pulls down the top of the frame. Still leaving a pretty significant gap that is very much not straight.
reamer
Actually is the right side (passenger) too close? there needs to be some room for the door gasket....
Rumcustom
Gaps
Here is the gap on mine. Exactly 1/4” between the windshield frame and the door window frame, with paint. Weatherstripping is installed and the doors close nice and snug with no problems. I also included a measurement from the front door lip to the edge of the door window frame for your own reference to see if your frames are installed properly. If you had the front door post replaced on the driver side that might be the reason for the extra distance. You could verify that by taking a measurement on both sides in the door opening between the front and rear door posts and compare them.
71 CA Bronco
What I was thinking. Passenger side is too close.
When I was dealing with this same issue was able to slightly tweak the cowl and attached the turn buckles at the roll bar to keep it there. I'm sure more will chime in here but it appears the passenger side is the real issue. Needs more gap. Especially if you plan to use the chrome trim.
Check your passenger side B pillar to door gap. If there is room you may be able to solve the tight fit at the windshield frame by a couple of shims behind the hinges.
AZ73
Mine look like your driver's without the screw that goes through the dash in. When I put that in, it pulls it back. Your PS looks way too close.
Rumcustom
One more thing. It's never too late at this stage to fix it to make it right. You probably have a ton of work into it to get it this far, and after you have a beautiful paint job on it you have a ton of additional work to finish putting it all together before its "done". Take a step back after you determine the real problem and consider moving metal if you have to in order to get it right before paint. You'll never regret doing the right thing, but if it's not right you will always notice it later. I guess it depends on your final plans for the Bronco, but that's just my opinion.
71 CA Bronco
I just checked my gaps and one is 1/2" the other is 3/8". They fit nicely. However this was by far the most frustrating part of my build. As others have said, you change one thing and it changes in another area. It took a long time to get mine right. When I finally had them the way I wanted I drilled a couple of holes through the door hinges to line up after paint.
Y
Yooper74
Thanks for input. He ended up getting it pretty square away by pushing the window frame around a bit. Did not end up moving the windshield frame. I'll get some fresh pics up later.
Rustytruck
My 1974 on the drivers side has the same problem from the factory. the lower windshield channel is in the wrong place. my problem went away when I went to door inserts. its too much to fix the problem may be able to help some by dealing with the body mounts but that will effect the door gap and alignment.
