Windshield support/turnbuckles
Scoop
Bronco Old Fart
Cuchara, CO
Gary,
You would not happen to have any pix of that old setup would you? How did it attach to the rollbar? The allthread that I selected is 3/8 thick, and I was thinking about flexing, but it seems pretty rigid, and I am thinking any added pressure will only make it more so...I think conduit with foam my look better than allthread though...
Thanks for the input...
R
Sorry, looked to see if I had a pics that showed the set up but could not find anything. I attached it to the roll bar with a 5/16 bolt attached to the end of the conduit and then threaded into a tapped hole in the roll bar. Sounds funny but I used a plumbers rubber pipe plug to attach the bolt to the end of the conduit so it stuck straight out - the kind of plug that expands the rubber when you tighten the bolt. Hard to explain but it worked fine as a ws frame support! The rubber actually allowed a little bit of give which was probably a good thing.
Madgyver
Bronco Madman
@Madgyver - what kind of retaining straps did you use?
:cool:
They are just flat pieces of heavy guage sheetmetal used in the pipe trade.
Pics will do better than me trying to explain.
Sporto
Sporto
I purchased the set from BC Broncos and I am very happy with them. They are very rigid and well made. I tried several different ways to mount them to the best way that offered the most support was to mount them to the side of the rollbar and run them straight (not angled) towards the outer bolts that hold the soft top riser to the frame. I then tightened up the turnbuckles and there was a noticeable difference in how firm the windshield frame was.
I recommend drilling and tapping the holes in the rollbar as this gives you the most freedom in placement.
If you have a rollbar (minus the cage) and you're not happy with the way the windshield frame bounces around with the soft top on or off, these are a good purchase. Just my 2 cents...;D
