@EPB72
Can you elaborate on this?
I read a little about this, but it was for LS engines (having a red crank LED, same as me)
my cam sensor is setup as digital falling
my wires match the picture
yesterday I re timed my cam sensor, she is now stabbed at 185 degrees before top dead center.
Same thing, cranks and cranks, green blue green blue then finally red 6th led
So today I will:
Test for spark
test fuel injector power wire and PCM pulse. I have been told the Holley will not fire the injectors if the cam/crank timing is out (FUN!)
I am considering changing my coil driver wiring to match @yakelys69 col driver wiring (remove 4 of the signal wires)
After that I am stumped
I do have a hall effect style crank sensor in the mail, but it is my understanding it should run with the setup I have
Riding the roller coaster
Not a ford in the picture but very simular...the red trace is a 2wire crank sensor the blue trace is a 3 wire cam position sensor,,,
So on the red trace where the missing tooth is you see it comes from the bottom if you were to switch the wires positions in the connector of the crank sensor the red trace will be inverted meaning the trace will then be coming from the top at the missing tooth.. the PCM is looking for a specific waveform...maybe switch wires or jumpers to temporarly switch wires to see if makes a difference...
My experience is with OE all makes,, no real experience with the Holley stuff
I'm curious as well if you are getting injector trigger....are you able to see any data like an RPM pid?
