86caprirs
So i get myself a 74 Bronco.The body has been hacked on so that 40" tire fit the truck.Fine, no big deal.I am making this a offroad unit anyway.So I spend some time this weekend and clean up wiring that was horrible.Then I have to relocate some stuff. Under the hood I see the rad support is hacked up and the rad is bolted to the front grill.The rad is also leaking to. Sigh. OK, i can deal with this.I llok more and find that the front rad support also supports the front fenders that was so nicely hacked that a body mount was broken off and the front fender was being held up by the bumper.So i deside to look arround some more.......bad idea. I find that the front pinion is loose and wobbling arround.Then I go to get the drive shaft for the front and it is siezed.I can't even pull it appart to install it.The rear driveshaft had about an inch play at the splines up and down. The trans is hard to get into reverse and 1st and it has a Duff shifter that is really worn out.Speeking of worn out,the steering column is an automatic column from ????? and it is really loose.Then I find that the steering shaft to the box does not stay on the shaft and it has a center piece on that shaft that flops up and down and arround and barely turns the tires.I guess a 77 steering box was put in as an upgrade. The rear support for the bed has split and cracked causing the body to basicly start to fall at the rear. all that and the Bronco was actually a automatic before the floor was chewed up for the shifter install. Oh man. I spent alot of money for a piece of crap.
Where do I even start for repairs?
I was thinking that I have to remove the front clip and cut the already hacked up inner fenders roght off. Then make a tube structure so I can hang the fenders and make new inner fenders.Then I can mount the rad properly. I did buy a Explorer rad.Nice and thick but almost the same size as the one that is in there now.
The rear I will just weld in some new channel to stop the droop.
Steering column and steering shaft I have no idea how to repair that. Maybe something custom.The engine was from a 86 F-150 and has the Ford plastic stock F-150 steering box that is just millimeters from the steering box.
I would love to get a C4 and D20 back behind the 351W
I did buy some Prelude seats to install into the Bronco one day.Very nice seats...even for a fat guy like me.
I guess I will get some custom driveshafts made for the truck $$$$$$$$$$$. I don't know where else to get parts from.
Any sugestions would be great. I heard that this was the best place for info.I have searched some stuff but others knowledge would be great.
Oh well. Any of you guys live here in Canada? I NEEED PARTS..........
