So I purchased a np435 (Craigslist deal) looked for the 10 spline input shaft and square bolt pattern . After installed and bench pressing this dang Dana 20 into place and failing for half an hour I've realized the reason it won't go in . The output shaft is obviously larger diameter and after counting 33 splines ! Is there anything I can do to make this work ? And does anyone know what model this trans is ? I've already rebuilt and painted it . I also have cut the tunnel and purchased a gear banger so needless to say I would hope to be able to make it work .
