bahowe1
Hey guys. I've done some searching but can't seem to find the same issue, but I'm hoping many of you have experienced it and know the answer.
'74. With wheels on the ground, when I turn the wheel, I've noticed I have some slight play in the tie rod ends and drag link. I've let it be and just enjoyed the rig, but finally bit the bullet and bought the tie rod end/drag link adjustable kit to replace it all.
This afternoon I went out to knock out the job and ended up with a head scratcher. I noticed the castle nuts on the ends were not really snug, but cotter pins were in place. At first I thought maybe I should have not bought the parts yet and instead just snugged them up, so I did, but noticed I ran out of threads on the tie rod ends before it got snug.
So, I hoped the new kit was appropriately sized. However, I noticed the same thing. Because the nut runs out of threads, it means the tapers of the holes are not contacting and tightening the connection. The drag link appears correct, it's only the tie rod ends.
I've never seen anything like this before, but it's the same on both sides. Any thoughts on how to fix this? I can't imagine as thick as the steel is that the hole has wallowed out??
Thanks in advance!
Thanks in advance!
