Tie rod end at pitman arm?
jperry1290
I currently have a heim steering TRO setup. I am looking to eliminate the heim that attaches to the pitman arm. Can I use a tie rod end in place of the drag link end? I have found some custom Chevy one ton tre’s that have better articulation than stock Chevy tre’s.
I’m trying to find one that is the same length as the heim so I can plug and play without cutting and re-welding the drag link.
AZ73
You'll need a taper insert since you're heim bolt is probably drilled straight through the pitman. For one ton you need to make sure the hole in the pitman arm is the size required for the insert. I used this:
https://www.ruffstuffspecialties.com/catalog/DLINSERT.html
As for the tie rod end, it probably depends. Do you have a lift? If not you MAY be able to get away with a standard tie rod end, but I wouldn't want to try it. The problem is the drag link has a much higher angle required of the end. If you can get a custom one that allows rotation for the higher angle while being the length you need, you're good to go.
Or change pitman arms back to a tapered one.
I doubt you will find one with the correct threads to match the hiem.
jperry1290
jperry1290
I went to all the machine shops and the would not weld or machine me new parts, due to liability. I did find a welder that will work for extra cash on the weekend, so hopefully problem is solved just a matter of getting it done. I will just switch to all GM 1 ton ends
