BoltBuster
- Jun 5, 2002
- 2,051
Sounds like we have spark and fuel. I would now, check for TDC (Top Dead Center) on the number 1 cyclinder and make sure the rotor is pointing at the plug on the cap that would be number 1 and your hermonic balancer is at 0 if you have one, you may also have to mark this with a pen on the side of the distributor.(follow the instructions on the link from MI-Bronco)
If the rotor is not on top of the number 1 plug postion in the distributor then your out of time.
How do the All plugs look after you have tried to turn over? soaked in gas or dry?
If they are dry then thats a good thing, so they can fire. If they are wet of gas or water,Then you may have another problem and the plugs are becoming wet fouled and will not fire.
