1969’s build thread
1969
Reno, NV
I got the passenger side bracket back from powder coat today. It’s coming together!
And the stock lower pulley should clear no problem.
Make sure you run a robust ground cable between the alternator body (one of the mounting bolts is most convenient) and the engine. Or a common grounding area that the engine is grounded to.
And of course, make sure that grounding the engine to the body is a prime part of your grounding theme.
With all the painting and powder coating going on, I'd just make sure that bonding everything (or at least most things) together is a good practice. Because they're no longer going to be contacting at normally conducting surfaces.
Presumably the body is going to paint at some point too? If so, it becomes just as necessary sometimes, to bond body panels together with extra straps or wires, to make sure that they are all part of the system.
After all, it doesn't do you any good to ground the headlights and turn signals to the core support, when it's no longer getting good contact with the rest of the body. Especially the few grounded panels that there normally are.
Keep it in mind when welding any new panels, or painting any old ones, where they need a good connection. Like the windshield frame, as another example.
1969
Reno, NV
Thank you for the information Paul. It’s always appreciated. I’ll have to revisit this when I get to doing a new wiring harness. The body won’t be going to paint, I want to keep it looking old and original for as long as possible. The only body work will be fixing the floor pans and firewall so I’m not flint stoning it.
Yeller
Rogers County Oklahoma
let the body tell the story of its history :)
1969
Reno, NV
Pulled my original heater box today.. not sure how it ever worked whenever it last did? Luckily no rust at all in and around there.
1969
Reno, NV
1969
Reno, NV
I’ve been working on getting the front clip off. I got some of the bolts off no problem, but I’ve had to cut most of them off. Everything looks to be in good shape for the most part. No signs of rust at all.
Is the front of the core support slightly angled back?
Speedrdr
Legend in my own mind
Paris, MS
View attachment 926500 View attachment 926501
According to my neighbor who restored a ‘73, the core support indeed has a slight rear slant. I honestly don’t remember how mine looked before I unbolted and angle grinder assaulted mine.
Randy
1969
Reno, NV
Randy
Good to know. I’ll have to find some measurements to verify everything is where it should be.
Looks ok from here, but I don't know the exact angle it sits at. Won't hurt to verify and have another data point!
With it all apart, are you going to clean up the cut for the steering box? Or better yet, do what Ford did and add a "bump-out" to the panel? Cover up the hole basically.
I always thought a pre-made panel you could buy would be a good benefit. But in reality, if you can weld, you can probably bend your own.
A pre-made one though, would make it easier for those that can't easily weld it in place, and just use screws or rivets.
1969
Reno, NV
I’ll have to take some measurements and compare.
I’m not sure yet what I’ll do about that hole that a previous owner cut with a torch :rolleyes:
1969
Reno, NV
Passenger side - measured straight back off the firewall
Driver side - measured straight back off the firewall
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
I will let someone with 1st hand experience chime in, but it is my understanding that every factory Bronco comes with a 1/4 inch discrepancy between left and right A pillars.
And any discrepancies aside, if your body was fitted together properly before you started taking it apart, then the rake of your core support is correct.
After all, almost everything relies on almost everything else to be at least close! 😉🙄
