1971 Stroppe Baja Restoration
TX SS
Houston
The carpet looks really good and you did a great job on install. Just having put carpet in mine I know what a job this is.
Baja71
Baja71
Thanks! First time for a carpet install. The product was well made by ACC. I also added their heavy rubber backing for heat and sound. I'd definitely buy from them again.
Fireball05
Going to need to remove your shoes everytime you get in! :)
Nice job with the carpet, looking good!
74BroncoCO
New accessory
Baja71
Baja71
Take a back seat.
The rear seat frame was still wrapped from the powdercoater. I'm guess those little dimples with smooth out once I get a few butts back there. ;D
74BroncoCO
Gee, there's another accessory for just that:
Can't wait to see you cruising this thing around!
The wheel well carpet doesn't cover the whole qtr panel, so I guess I'm looking into qtr panel inserts, or leaving them bare.
The current crop of parchment vinyl side panels are very slick. Not particularly Stroppe-correct perhaps, but very slick looking.
Here's a set in a friend's Bronco.
75junebug
NW Houston Tx
Looking good TW.....I finally made RU this year, and managed to keep mine intact until Saturday afternoon.....Maybe see you in the show and shine next year?
Baja71
Baja71
Buckle Up!
My '71 seatbelts really were in great shape, except for the buckles. So a little refresh was in order.
Baja71
Baja71
Lacing? On a Bronco??
Not sure what good this 'cowl lacing' rubber weather strip does, but I installed a new one.
Baja71
Baja71
Straggler
This little bracket was the sole leftover from the powdercoater. To be honest, it sat because I forgot where it went. It wasn't until I decided to look at the rear reflector installation that a recalled the lone bracket. It was a perfect match. Home at last.
Baja71
Baja71
I also installed some NOS side lights...and took a gratuitous Bronco pic.
Baja71
Baja71
I started with Dennis Carpenter door weather strip but didn't like the consistency of it and changed to Metro which is much softer. I actually had to loosen up the AUX tank and slide it over a bit to get the lower clips in.
