250ci inline 6 cyl needed!
BROwN COw
I need a good used 250 inline six. (The difference is where the starter mounts.)
The engine in my Bronco that grenaded is engine code
D5DE
6015-AA
I need one with the same code.
RM70
Athens, AL
Is that a 200? It should still be a high mount starter in 75. How many bolts hold on the water pump?
BROwN COw
BROwN COw
Corrected. 4 bolts. 250ci
Other than the external clues mentioned, how do you tell for sure what one of these six cylinders is?
Engineering number? Casting date? Crankshaft code? Bore diameter I assume? But of course that’s more work. What about the type of cylinder head?
ntsqd
heratic car camper
Upper SoKA
The only distinguishing feature of the 250 that I know of is that it uses the small block bell-housing. The 200's and smaller use a bell that is unique to them. I'm dimly recalling that there maybe some exceptions to this?
RM70
Athens, AL
200 has a 3 bolt water pump, 250 has 4 bolts
200 uses unique bellhousing patterns, 250 is SBF
200 did do a low mount starter but it wasn’t until 1980 and they were called big bell 200s. Even those had to be modified to fit other transmissions if it wasn’t a c5 if I remember correctly.
I also attached a picture of a high mount starter 200, you can see where the starter would sit.
ntsqd
heratic car camper
Upper SoKA
As I recall from way back when a friend had a hot-rodded 200 in his 64.5 Mustang Coupe the 144's, 170's, and 200's all shared that "Small Block Six Cylinder" bell-housing.
OP, what is wrong with the engine that you have? It is the surest bet to fit back into the truck.
bmbm
The 250 block is different from the 144-200 being slightly wider and taller and has the SBF bell housing as stated. Ford made a few different block designs in the 144-200 to help make things more confusing. The 240/300 is larger than the 250.
BROwN COw
BROwN COw
Confirmed broken camshaft is why I want to replace it. The link to Ford six in the above comment is making me question my assumption to it being a 200. According to that chart, Ford didn’t make a 200 in 1975.
Update: it’s a 250 ci
ntsqd
heratic car camper
Upper SoKA
boy, did I typo that or what?
thom, way over on the Lower Left Coast. Bound to be someone(s) in your area who knows of a shop that can work with you on getting that engine sorted out and fixed.
