Is that a 200? It should still be a high mount starter in 75. How many bolts hold on the water pump?
4 bolt is a 2504 bolts. Yes, 200ci
The only distinguishing feature of the 250 that I know of is that it uses the small block bell-housing. The 200's and smaller use a bell that is unique to them. I'm dimly recalling that there maybe some exceptions to this?
As I recall from way back when a friend had a hot-rodded 200 in his 64.5 Mustang Coupe the 144's, 170's, and 200's all shared that "Small Block Six Cylinder" bell-housing.
OP, what is wrong with the engine that you have? It is the surest bet to fit back into the truck.
There's a name that I haven't seen in decades!
BROwN COw, where area are you in?
http://www.normansofshelby.com/
This place claims to have one out of a granada for $300 in NC, but it doesn’t say what condition it’s in.
Good idea! Rebuild and include torque/rv cam, slight head shave to get compression up and 3 angle valve job.Time to upgrade to a clay smith cam
