302 heads
johnbeck
The machine shop that is going to rebuild my 1973 302 said installing new unleaded valve seats and rebuilding the stock heads will run $600 +. New Edelbrock Aluminum heads aren't too much more. Any thoughts on switching to
the aluminum heads? Any other options for a stock rebuild with a little torquee cam? Thanks
My, how prices have gone up over the years... I remember when installing hardened seats would cost less than $150.
Or is that $600 for a full head refurb, including valve guides and new parts too? If so, I can see the 600 bucks being pretty decent for today's prices.
Ford did in fact use induction hardened valve seats even before unleaded came around. But at this age and likely mileage, and the need for a full valve grind, putting new hardened seats in would be a best practice most likely.
If you're into the improvements though, the Edelbrock heads are way above the originals. Should be an improvement in most areas in fact.
But aren't they over $1000 bucks a loaded pair? If not, then I'd say spend a little extra and go aluminum. If they're more than $400 bucks more than a stock rebuild though, well, I'd still prefer going with the aftermarket. Just that the price isn't quite so pretty at that point.
I'm sure others will have pros-n-cons of the heads. Hopefully you'll get some good replies. Lots of members running aluminum, so maybe they're chime in with their experiences.
blubuckaroo
Grease Monkey
Ridgefield WA
The thing is, when you switch to aluminum heads, the cost doesn't end with the heads. You'll need new hardened pushrods, adjustable rockers, and also you really should have the valve spring pressure/rate measured and shimmed if needed for your particular cam.
But aftermarket heads will improve flow in the upper RPM range. I have a set of cast iron Windsor Jr. heads. The performance difference above 3500 RPM is astounding.
I like aluminum heads. But you need to know what you have. There are different chamber sizes. You should also know what compression ratio you are starting with.
What you are wanting to do is pick up a little compression by getting the correct size chambers in the heads. Do not try to make up for too small of a chamber with an extra thick head gasket, you screw up the quench area and make a mess of combustion. The aluminum heads handle the heat better so you can run a little higher compression on the same octane gas. Figuring regular 87 octane you can get about 9.5:1 compression. This is a nice little boost in performance. The larger ports and valves work just fine with the small cam. You still get the boost in airflow without upsetting good idle and low end.
I ran a set of Trick Flow heads years ago with a small little RV cam. That was a fun engine. Overall it was built just about like any other street small block. Flat top pistons and an Edelbrock performer intake and RV cam. Even ran manifolds. My compression was a lot higher then I am recommending (I screwed up the math with an early 351 block). I needed premium fuel, but 9.5:1 should be fine on regular.
Off the top of my head, 58cc chambers are probably correct. Maybe 63s. Do you have dished pistons or just valve reliefs?
J
johnbeck
600 and some change to refurbish both heads. I'd step up to 1200 if it didn't involve adjustable valves, shims and the like. If I bought a pair of later heads, rebuilt them, what would I have to change ? I have stock exhaust manifolds but am planning on replacing them with headers for which ever heads I get. I have an Edelbrock carb. and intake manifold. My Bronco is my daily on the street driver - would like to end up with decent fuel economy. Need heads, headers, torque cam, possibly EFI for my engine rebuild. So many options - I truly appreciate your suggestions!
J
johnbeck
Don't know what pistons, haven't pulled the heads yet. I believe the 1973 302 has 8.5:1 compression ratio. I'll try to find out what chamber size the original heads have. Thanks!
Boss Hugg
I've been reading up on this in a book I bought and searching online... supposedly the 72 and earlier had 58cc chambers, and 73-up went to 68cc. Look in the valve area and see if there is a 72 or 73 cast on them. That'll tell you one way or the other.
rguest3
I have a set of 170cc Edelbrock Heads with 58cc chambers and they are specific to a motor with a Flat Tappet Cam. $975.00ish on eBay.
These are a nice upgrade for a street driven truck. Maybe add headers and small 4B carb.
Timmy390
Conway, AR
What pistons are you going with? Stock 73's are deep dish and stock compression is down at 8 or 8.5. Somewhere in that area.
It's about the combination of parts working together when you upgrade. Block deck height, pistons, head gasket thickness and head chamber size.
As an alternative to aluminum, GT40P heads are 59cc and are not near as $$.
Tim
J
johnbeck
The GT40P chamber size will help with my poor 1973 compression ratio. What year and vehicle did those heads come on? The machine shop hasn't ordered pistons yet so I can try to find the right set if the GT40P heads are my best option. Other than the chamber size does that head offer any other improvement over my stock heads? If I pick up used heads are cracks readily apparent? will a metal straight edge pick up a warped head? Thanks
Boss Hugg
The P heads came out of certain explorers. What I've learned recently tho is that they don't have very good valve springs and most aftermarket springs will require machining of the heads. Alexsparts.com has options tho. Also, the spark plugs are in the way of headers so you have to buy (or build) specific headers.
In short, swap in a 460... ;D
Timmy390
Conway, AR
I suggested GT40P's because they're the closest "stock" ford head you an get to aluminum aftermarkets. They flow well and are rated better then the E7's and even the GT40's. I got my set out of the junk yard for $30 each ;D
70's smog heads are junk. They CAN be built to handle up to 300HP but that's throwing good money after bad IMO.
If considering the GT40P's (97-2001 Explorer) as mentioned they can't handle much more than the stock Explorer cam (which isn't a bad cam at all). So you would need to check your cam specs against the stock explorer cam and upgrade as needed. The spark plug angle is no big deal. You can make the stock bronco exhaust manifolds work (I'm told) by doing some grinding on them. Using the stock Explorer exhaust manifolds is another option. If considering headers, Bronco Hut shorties work great on the Bronco. I'm running them with my GT40P heads.
As for cracks, you should always get used heads magnafluxed and pressure tested. Pressure testing is generally done only on aluminum heads but I learned the hard way magnafluxing can sometimes miss an internal crack. Found this out on a set of E7's during my 351W build. The cracked E7 is the reason I upgraded to the GT40P's I have now.
x2 on AlexParts. Got my spring kit from there. I'm running a bigger cam than stock....
It's all about cost analysis......
Tim
Rustytruck
stockish rebuild with a torque cam I would go with a set of small chamber 289 heads and flat top pistons. If your going to put 600 bucks into a set of cast iron heads.
If your not going for the compression bump 75 and later peanut plug heads have induction hardened seats so you can forgo the expense of hardened seats but still allot of expense with new valves and guides. Still you want to go with flat top pistons for the compression boost.
One thing you have to watch for in 1973/1974 302 engines is some of these motors have .020 higher deck height on the block reducing compression even more. My 1974 California Bronco motor is one of those odd bastards.
Now if your really planning to push your Bronco into the upper RPM range the the aluminium heads are a good choice but you will want to deal with all the extra internal parts and you will need to upgrade your whole exhaust system. If your going that far I would be using a newer 5.0 roller cam motor. Eliminating early flat tappet cam failure.
Now we got you running down the rabbit hole and spending copious amounts of your money.
rguest3
JohnBeck - if the machine shop is building your complete motor and not just the heads, then I recommend what I did with the 302 that is in my 69 Bronco in my garage.
You don't have to build a high reving engine to see the benefits of aluminum heads. The biggest benefit is the ability to run a little more compression for a given octane fuel. That helps the engine be more efficient. Get more bang out of each drop of fuel. The fact they breath better and make better power is just another benefit.
Builtnotbought0
Belen NM
i purchased this set of GT40 heads last week for 649...free shipping. They are 64 CC heads, 2.02 Stainless valves, 1.60 exhaust and swirl polished with undercut stems. they will also allow up to a .530 lift. Havent fired it up yet but they look amazing..lol
They sure look fast right there on the stand!
And those are some pretty big exhaust ports by the look of it too. Which heads are these?
I know you said GT40, but are they a specific brand and model?
And yes, they do look amazing.
Even more I think, once it's all installed in the engine compartment.;)
Builtnotbought0
Belen NM
