302 heads
Look pretty good, and at a good price too.
And I guess they're not the really big exhaust ports anyway, since those tend to have the two bolt patterns for use with the bigger headers.
Should be fun.
Builtnotbought0
Belen NM
Should be fun.
I micd the exhaust port last night and its almost 1/2 inch bigger than the stock...
Ok, that is pretty big then after all.
Guessin' if you have a choke point in the exhaust then, it won't be due to the heads!
J
johnbeck
Which is less complicated, 5.0 (newer roller cam) "Eliminates early flat tappet cam failure" or "went to 351 with EFI" . Can I use my C4 auto on either? "All about cost analysis". With wiring harness conversion, roughly what numbers are we talking? Thanks again!
Timmy390
Conway, AR
So many options.......
You can get a kit and run a roller cam in the block you have.
I personally thing that's the best option
Buy a running Explorer or pull an explore engine from the junk yard and rebuild it reusing the roller cam and lifters. You have to run an electric low pressure pump for a carb because there is not mechanical fuel pump prevision. Another advantage to this is you get better heads (GT40 or GT40P's) and the explorer front dress. Better PS pump and alternator. Good cooling fan too.
If you buy a running Explorer, you also get all the EFI parts you need. EFI Guy and work your harness or you can do it yourself (I did). Your only left with plumbing the fuel system which is no big deal. I'm running an external pump and the stock tank on my Ford EFI with no issues. Oh and the explorer trans is a popular swap.
Part out the Explore then scrap the rest. and you might get close to even. If staying carb, sell the EFI parts.
351W has some challenges but nothing you can't overcome. Hood clearance can be a pain and a 1 inch body lift is almost a must. You have to choose which intake you want to run both for carb and EFI. Again hood clearance.
C4 will bolt up to either the newer 302 or a 351W
I bought a running 96 E350 ($800) After parting it out and scrapping it, I was $60 or $65 in the hole. Worked the harness myself and run SN95 stang ECM
Price for each all depends on how you buy and what you farm out/do yourself. But that's with anything Bronco.
Tim
rguest3
johnbeck - How long did your motor last with a Hydraulic Flat Tappet Cam as is?
Rebuild the motor you have and enjoy it for a long time.
Find a 5.0L Roller Block and have it built and enjoy that one for a long time.
If done correctly, either will do great.
J
johnbeck
I appreciate the input! I'm looking into possibly buying a 5,0 or a 351, rebuild them instead of my 1973 block. Looking into small chamber 289 heads with flat pistons to bring up my compression ratio or aluminum heads if I stick with the old block. Looking at GT40P heads with 59cc chamber. I want to make an educated decision because I'll be living with it for awhile!
blubuckaroo
Grease Monkey
Ridgefield WA
A roller motor would be nice, but to me it's not a deal breaker. I'm not afraid of a flat tappet cam. Sure, I had a break in failure years ago, but that was only because none of us were aware of the changes the oil companies had made to their products. Follow the rules, and yours will be successful.
A couple of good points to the older non-roller motors are a better cam selection, and two piece oil seals. Yes, one piece seals fail too, and their replacement is a lot more work.
J
johnbeck
It's been 20 plus years since I even pulled heads. Could you give me a summary of break in failure and the rules to follow? Thanks
blubuckaroo
Grease Monkey
Ridgefield WA
When assembling the cam, use assembling lube on the lifter faces and cam lobes.
Adjust the valve lash before the initial startup.
Fill the crankcase with fresh oil. Either use a high zinc break-in oil or other conventional oil mixed with your zinc additive. I use Comp Cams break in additive.
Prime the oil pump with a drill or speed handle with the distributor out to access the oil pump drive.
Have the engine ready to start and run.
Have the distributor static timed, carb primed, and coolant filled as well as possible. (have more coolant on hand)
The idea is to be able to start the engine without excessive cranking, and to come up to speed without delay.
Once fired up, immediately bring the idle up to 2000 RPM. Keep it there for at least twenty minutes.
Continue to monitor the water level and temperature, and oil pressure during this run-in.
After this initial run-in, you need to time the engine properly with a timing light and readjust the and idle speed and mixture.
I like to change the oil after the first 500 miles. I continue to use the zinc additive for the life of the motor.
J
johnbeck
Thanks Blubukaroo. How many shops will prime the oil pump/system, prime the carb, etc.? How critical is it? What is ruined by excessive cranking, not getting up to 2000 rpms? Thanks for taking the time to write out that list! I looked at your "under the hood" photo - very nice!
englewoodcowboy
Lick Creek Restorations
Head rebuilding cost sounds right for a complete rebuild, new springs etc. Being that is the cost with your old stuff and if you are willing to do a little more in the spend department, the easiest and best way is to contact Edelbrock and talk to them. They can sell you complete kits, heads, intake carb, cam, timing set, lifters, push rods the whole nine yards designed to work together and fit your application. You can cherry pic items if you already have them etc. but that is the easiest way to go about it to have all of the right parts, the right needs to get the right end results and a single kit to put it all together so you are not chasing your tail. Now if you don't mind doing the leg work, then there are many other options that may save you some money over my recommendation but ill cost you more in time. That is the fin of these things, making them suit your needs.
sykanr0ng
Buyer BEWARE These are Procomp heads not the best track record.
On the various Mustang forums they say the castings themselves are okay (not great but okay) the problem with them is the work done and parts used by the company to make complete heads.
The trick to buying them is get the bare castings and have a good shop finish them and then equip them with good parts.
Of course that does get them a lot closer in price to better heads.
blubuckaroo
Grease Monkey
Ridgefield WA
Excessive cranking is going to wipe off the assembly lube you've applied to them.
The cam lobes are oiled by oil slinging off the crankshaft. A faster spinning crankshaft will supply more oil. For cam break-in, more oil is better.
broncnaz
Lots of options and lots of good suggestions. I would really tear your current engine down find out what you actually have. I'm not certain but I think that broncos may have stayed with 58cc heads. Id check out what you have before looking at getting a set of 289 heads as they will be the same cost to rebuild with really no gain in performance. GT40 heads would gain you some but again need work to rebuild and use but you'd get a small gain for the money. Aftermarket heads will cost more than just the head price as was said other parts will be needed. So more money but bigger gains can be had, But don't expect gains like the numbers that the aftermarket claims the motors we tend to build for broncos are relatively tame and you wont see a big HP increase just by installing good heads. The camshaft is really what makes the power.
Several years back I went thur the same process on my 73 my stock heads were not quite right after a rebuild so I needed to do something. although the gt40 heads were not really a option at the time as they were just coming out. But once I added up what it would cost to rebuild and modify my stock heads.(I also wanted to convert to adjustable valves) Aftermarket heads were not much more and I would have better heads right out of the box. So I went aftermarket. While I'm sure there was a gain I really couldn't say it was a big gain. Like most aftermarket stuff the gains are mostly seen on the top end so I'm sure it gained there.
In the end do what makes you happy. If its your first engine build then keep it simple listen to the advice given make some informed choices and don't go to wild. Most first time builders wished they had done something different, But its all a learning curve.
