331 Stroker???
73azbronco
331 being a hi rpm application while a 347 goes for max stroke and maximizes all the torque a 302 block can manufacture.
Couldn't it be said that a well built 302 could be a higher rpm app than the 331 due to the shorter stroke?
True, but with 30 less cubes, you just lost well, 30 cubes or roughly ten percent of your output. A 331 was designed to run the 1/4 mile at 6-10,000 rpm and give you ten percent more volumetric efficiency.
