- Oct 14, 2004
- 5,001
In the process of reworking my stroker (395) and switching from a non roller to a roller block. Plan is/was to use the rotating assembly I have with new bearings and rings. The roller block is at the machine shop but I haven't taken them the rotating assembly as the current engine is still together. Right now they are hot tanking and pressure testing to make sure the block is good and then proceed from there. The machine shop, which was highly recommended to me, doesn't like the fact that my rotating assembly was balanced to 50oz rather than the normal 28oz for all 351w engines. He says now is the time to correct something that should have never been, says 28oz is much better on the life of the engine, journals 2 & 4, especially a stroker. This will add another $300+ for a cast crankshaft and then another $150 for flexplate and balancer. Every nickel counts and adds up but I agree if necessary this is surely the time for it. The current engine was built in 2005, I didn't know anything about strokers and was told 50oz was better, geez. It's lasted 15 years and still running, just blowby and a little smoke which is due to dust and dirt I'm sure.
Long question short - Which is better and why?
