I am going to say something that a lot of people will disaggree with but they are wrong. They read too many magazines and do too much bench racing. Do not drink the Hot Rod, Mustang magazine Coolaid. This 393 or whatever you build is going to make nice impressive usauble torque even if you bolt on a set of crappy small valve heads, a stock 351 windsor cam, and stock cast iron manifolds. Yes that set up will hurt the top end but think about it before you put a lopey cam in. Even if you want a really fast street machine just how fast can you really drive a bronco with 35 inch tires safely? Buy a cam that has a realitively short duration, as high a lift as you can find and virtually no overlap. The intake valve really doesn't need to be any larger than 1.9 and the exhaust will live with 1.5 ish. Watch out for high compression ratios and RV (high lift no overlap) type cams. They are able to run higher compression ratios than you might expect due to the fact that there is very little scavenging and the residual exhaust gas dilutes the incoming fuel air charge. But they can be a real bitch to start, When you start it you have a fresh fuel air mixture with no residual exhaust gas and the resultant first firing will detonate severly and is hard on starters as well, but they do run like a stripped @$$ ape on crappy gas once they start running.
In 1984, when I was still young an wreckless) I built a chevy 350 with a 305 RV cam that the manufacturer said wouldn't let me rev the 350 past 3500 RPM, just because the peak HP was being made at 2500 RPM in the 305. Turns out it got flat at about 4500 RPM. This unexpected result is due to the fact that the 350 would draw in more fuel air mixture due the the larger displacement. I had 9:1 compression and experinced the hard starts, but no detonation once the engine was running. It was faster in a CJ5 than anything I every faced on the raod up until I reached like 65 MPH or so then it would start to flatten out. It was still able to pass at about 75 but I admit there really wasn't much left. Speed limit was 55 and I really never enjoyed driving the little CJ faster than 70 MPH. One blown out 33" tire at 70 MPH in one of those things and you know what I mean.
Deal was it got there so fast I was one impressive offroad and street engine. I had to wire the quadajet secondaries to just barely open otherwise the damn thing would go from primaries to WOT in just a heart beat due to the fact that the 2500# Cj wasn't much of a load and then engine constantly made exceptional vacuum with that type cam.
If you keeep in mind that there is no reson to build an engine that makes top end HP where you will never use it you can build some very impressive torque monsters that will get you going in a hurry, white smoke all four tires, and so what that it hit peak HP at 60 MPH and fell off completely at 80. Problem is some cam manufacturers have no idea what the Real top RPM of the cam is, or where it really drops off. Once they dyno the peak they are basically done. They also may not know where a 351W cam will make peak HP in a 393.
If you want to go 100 in your bronco then ignore me completely.
