3G and eliminating Regulator
flousberg
I am trying to clean up my engine compartment and get it ready for paint. What wires can I eliminate since I went to 3G. There are two wires I need to know what to do with. One is yellow and combines with a larger wire and goes to the battery side of the solenoid. the other goes from the Regulator "s" terminal to a plug by the fire wall.
Viperwolf1
electron whisperer
Frank,
The yellow wire was there to power the regulator. It can go away. The green-red wire was there to turn the regulator on. It can go away but it's one of the few switched power wires under the hood. Only 12V with key on. You might find a good use for it.
