Looks like you put in an MSD distributor. Hopefully yours has a functioning TFI module - mine was crap from the beginning. It would start and run, but it ran like absolute CRAP! I chased that issue for a couple of days. Worst part was that, since everything was new, everything was in question.
Eric
I've heard of tuners having issues with these as well - thankfully the PO of mine stripped the MSD guts out and install all Ford internals (which never fail) and I've got what I wanted anyway, a superior body with reliable guts.
Nice to see you got it in there - was it easier to point the intake that way or is it just the way your throttle setup was left? My first EFI conversion has the intake pointing the other direction...
Well you guys scared the hell out of me with the MSD horror stories, so I sent it back.
Received the Mallory distributor today. A much nicer unit than the MSD. It just feel more stout.
Too much injector is much better than not enough - bigger injectors work perfectly fine at low duty cycles...
Well the EFI stroker fires right up after a little surgery to get the passenger side header on. It idles great at start up then slows down and stumbles. I tried running codes but I can't get my code light to blink. I've checked all the fue and disconnected all the extra stuff going to the battery, stereo, projectors, fan, etc and still no codes. Not sure what to do next. I'm thinking the stumble is from the tps. I disconnected the tps and it run about the same.
What exactly is happening? Just stumbles, or the idle surges? Does it smooth out if you press the gas pedal in a little? Do you have the TPS set properly? If you have a moated, you can easily check the output voltage, otherwise you can probe for it. If you are getting the right voltage, move on.
What about the IAC - it is going to let more air in at first start than at normal idle. I forget, did you apply a tune to this yet? Do you have a wide band O2 hooked up? The wide band should tell you what's going on since it sounds like a fuel/air issue at this point.
It starts up fine cold and runs pretty smooth until the idle drops then it stumbles quite bit. If I give it gas it smoothes out. When I let off the gas it stumbles and eventually dies. I have a new tps on it.
If I turn the idle up to 1200 rpms it runs smoothly.
I have the two O2 sensors that were on my 302 HO. No tune and I have no way to tune at this point. I was considering the quarterhorse.
