Something that always bugged me with my previous 5.0 engine got worse with the 351W/408/what ever. The upper radiator hose, what with an OEM style radiator and Explorer 5.0 front dress, is the high point in the system. Air in the coolant system is not your friend, unless you like corrosion. Some cars with similar systems have an air bleed expressly to remove air from said high point. Simple. Warm up engine. Open bleed port, expel air.
I bought a 1.5" x 45 degree stainless mandrel bend. Already had some 1/8" NPT stainless weld bungs. Drilled/welded bung into tube. Substituted it into the upper radiator hose. I happened to have some stainless high temp/high pressure Schrader valves. I'd prefer a 1/8 NPT x -3AN fitting with a -3AN cap but I don't have one. Schrader valve does the job, at least for now. Worked as hoped for.
And, thanks to the "Highlander" hood, it clears.
Tell me more about the rad over flow bottle? Store bought or hand made?
Canton. Embarrassingly expensive but I wanted the bling. It's designed to take pressure so it has a regular radiator cap. Overflow tube on the radiator filler neck is plumbed to the bottom of the can so it will push coolant back into the radiator when it cools off.
This:
https://www.summitracing.com/parts/ctr-80-200r
Yes Canton is very proud of their Overflow tank... But, if it works...
Thank you for the info...
Lars- is there specifics on mounting height of the Canton overflow in relation to the radiator cap?
I took the plunge and joined the Canton over priced bling club.
Couldn't wait any longer on my other builder, who got Covid and hasn't recovered well...
Broke the piggy bank again (more like, smashed to smithereens) and ordered a replacement from US Radiator the same day. According to their website they are 2-4 weeks out so I have some time to obsess about other stuff.
