    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
SOLD 408W Stroker EFI Motor
Status
Not open for further replies.
rcmbronc
Tomah WI
New built this year 408W stroker motor. This is a great running motor with tons of power. I am probably going to try a SC Coyote next so this is going to go. Motor has about 200 miles on it. Never dynoed. All good parts used throughout. I will see the motor as a long block or complete with EFI and also EFI computer if you want. I will separate as requested.
408W - Late model roller block
.030 Over Bore, magnafluxed and decked
Ohio Crankshaft rotating assembly
4340 Forged 351W crank
H-Beam rods
SRP Pistons -19CC (10.3-1 CR)
Internally balanced
Moroso Windage Tray
Moroso Oil pan
Melling HV Oil Pump
ARP Oil Pump Drive
ARP Head Bolts
AFR 205 CNC Heads
Fel Pro MLS head gaskets
Custom FlowTech Induction Hydraulic Roller Cam - Max 6500 rpm
Double Roller Timing Chain
1.6 Full Roller Rocker Arms
New Timing Cover
Aftermarket Balancer
Holley Hi-Ram EFI Intake
Holley Sniper 102mm Throttle Body
60 lb Bosch Injectors
Crank Trigger
MSD Cam Sync
Holley Terminator X EFI - This will also control a 4R70W trans
Coil on Plug LS type ignition
Total package sell for $7,200. Engine only with intake and throttle body $5,300. I can separate other as needed.
rcmbronc
rcmbronc
Tomah WI
More Pics
Status
