- Joined
- Nov 3, 2003
- Messages
- 51,619
One other thing is through all this I had the body off.
But you do have the full exhaust plumbed in, correct? Don't want open exhaust giving the O2 sensor fits after all.
I also removed the stock starter solenoid and direct wired to solenoid on the starter. I must have messed something up as not the start function on the original key does not work. Just another thing to figure out.
Now how come you added another layer of mystery and imagination and hassle?;D
Depending on the starter, you really need to keep the standard relay intact. for several very good reasons in fact.
First is that the solenoid on the PMGR starters uses more current and taxes the ignition switch along with all the other modern stuff you've got on it. Yes, it should handle it no problem. But with modern stuff it's hard to say and I prefer not to think it's just coincidence that so many people that have done what you did also had their ignition switches fail after.
Second is that the relay is a nice handy spot to put extra power wires. Even if you don't like the look of wires there, there are a lot of wires that would prefer that area to being mounted to the starter.
Otherwise where do you have your power wires? Everything down at the starter now, or do you have a power stud somewhere up on the fender still?
The third reason is that the starter can act like a generator and produce enough signal to keep itself energized and spun up. The starter relay on the fender isolates it and give is a positive shut-off.
Yes, millions of vehicles work this way just fine. But ours don't so we keep the original starter relay in play.
When you found your start function did not work, did any other power items work? Where do you have your main power and charge wires connected now that the starter relay is gone?
