4R70W swap ??
69BroncoDad
Rutland
I do apolagize in advance...I know this has been gone over time and time again...but I'm not finding a few things in my search....
OK so I got my 2000 Exploder in my garage getting ready to tear it all apart.
want to go serp..FI..and 4R70W.
Have 69 EB with 302 from 69 Couger..edelbrock aluminum heads the timing cover from 5.0 will fit correct??
gonna get Baumann controller and RJM harness
4R70W..do I use the flywheel from the 5.0 or other?
Thank You again...
G's Baja Bronco
Sunny SO CAL
The timing cover will fit.
the flywheel you should use is the explorer 5.0 one together with the smaller high torque starter.
have fun :cool:
tasker
all knowing of nothing
NH
BRONCO LOCO just put one in his and will be at BYOB DJ....
69BroncoDad
69BroncoDad
Rutland
well my donor exploder was stolen...but I got it back unharmed so started pulling it apart last night..
Rusty.. My 69 302 is all rebuilt never started is the one i wanna use
Has anyone used the converted 3 bolt crank pully for the ser set up...or does everyone just have them rebalanced?
trailpsycho
Not sure if you were clear on this, but you will have to use the Exploder timing cover on out to run the Expolder front dress.
As well, the engine will not have the correct imbalance for the Exploder flexplate/flywheel. I believe you can reuse the one for your current C4. As you may already know, BOTH the balancer AND flexplate/flywheel will have to be rebalanced or there are other options ($uch buying new) to achieve correct imbalance...but probably easiest to just rebalance the harmonic balancer...and reuse your C4 flywheel. You might be able to find someone locally to do the flexplate/flywheel. I couldnt find a shop in Indianapolis willing to do so....and we are supposedly a race-friendly city.
Good luck!
69BroncoDad
69BroncoDad
Rutland
I'm doing this all from scratch...only have the flywheel from 435...and haven't found anyone locally that will rebalance the Harmonic Damper....
which is why I was thinking about using the 3 bolt serp pully
but now i gotta figure out what to do about the flex plate...
Anyone got a good place I can send the two to get balanced??
trailpsycho
Someone can correct me if I am wrong, but I believe alot of folks have used "dampener dude" or "dampener dudes"....maybe its "damper dudes". Either way,the Explorer front dress is a shorter dress and it requires the correct balancer to achieve alignment. I am not aware if there is an off-the shelf specialty part that will work...but it would likely be expensive.
http://www.damperdudes.net/
Also
http://www.damperdoctor.com/
There should be an off the shelf part that you can go to for the flexplate. This info is covered inseveral diffferent threads, so if you havent yet, you might try the search function above...lots of good info in the different build threads as well, if you can find a build where someone was running the 4R70W...I am not up on everything for the 4R70W swap as I have only done the 3550 and NV4500 swaps...but I do know the issues utilizing the older 302 and the newer 5.0s with older and newer trannies...so I just wanted to make sure you were aware of the points above before you start spending good money after bad...
Good luck.
John
69BroncoDad
69BroncoDad
Rutland
Driven auto Parts has a pully that bolt up to the 3 bolt 302 damper for the exploder conversion..$80 now to figure out the flywheel
164 tooth
11-7/16" (sometimes listed by a few other numbers that are very close, 11.400" for example) bolt circle
28 (or 28.2) oz-in imbalance
Find a flexplate (not flywheel) for a C4 or AOD application.
