5.0 will not start when warm
SC74
SC74
#9 is the ground on the intake I'm referring to that got tugged on.
  • RJM PAGE 2.pdf
EricLar80
Idle screw is still a possibility. You can start by turning it in 1/4 to 1/2 turn to see if that helps, but set it back again and get the plate if you think you want a permanent solution. It’s worked for a lot of people because you get much better repeatability of the actual idle air. Also make sure you have a good return spring so you know the throttle plate is closing correctly and to the same spot every time.
In fact, did you change your throttle body or intake tubing as part of this? Aftermarket throttle bodies are known to be problematic.
Where is your coolant temp sensor located? Engine side or radiator side of the thermostat? Best location is on the thermostat housing on the engine side.
Will the engine start correctly when it is fully warmed up (180+)? Or is this just a 150 degree issue?
surfer-b
have you opened up the PCM and looked at the capacitors, I know they will cause it to do some crazy stuff if they are cooked, I know mine would search for idle then die, a little different than what yours is doing but still worth taking a look, and should be replaced regardless
ransil
pin 10 should be depopulated at the computer.
checking 40 & 60 remove the computer plug and ohm them out to engine ground
#9 on the RJM harness is most likely the HEGO ground
ransil
open the throttle plates on the throttle linkage, turn screw in, might high idle but as long as its running, tweak later when you fix it.
SC74
SC74
Is there a proper procedure to turning the idle screw? IAC plugged in or not plugged in? During choke circuit or after choke cuts off? I'll order that plate because I don't think that could hurt anything, regardless of the problem.
Throttle body and intake tubing are the same as the old motor, no changes. It is the stock throttle body. The only thing I did was drill a hole in the intake tubing for the IAT sensor.
I'll have to check on the location of the coolant temp sensor and report back this evening. I'm at work all day and won't know until I get home.
It will not start at all after 150, regardless of temp. It needs to be less than 150 to start.
No, I have not touched the ECM yet. I will tonight.. first thing I'm going to try is check those grounds that ransil has advised to do.
EricLar80
Excerpt taken from this site.
Once the engine reaches a warm non-surging idle, unplug the TPS, IAC, and SPOUT connectors.
If the engine stalls, you will need to OPEN the throttle body stop screw to give the engine enough airflow to idle. If you have an automatic transmission, place the vehicle in gear with the parking brake set and chock the wheels to prevent the vehicle from moving. Be sure someone stays in the vehicle at all times with their foot on the brake. With the tps, iac, and spout unplugged, adjust the throttle body set screw to reach the MINIMUM rpm the engine will idle. Then shut off the engine and turn off the ignition, plug in/reconnect the iac, tps, and spout connectors. Fire the engine back up and allow a few drive cycles for the ecu to readapt to idle correctly.
SC74
SC74
I think it is fixed, thanks to everyone’s help here!
Ransil, I did check the grounds on the ecm harness and had less than 0.5 ohms. I also checked the soldered wires and they checked out well also.
The culprit... idle screw! I did the process that EricLar80 posted, and bam it cranks! I had played with the throttle plate screw at first start up, and I must have not gotten it back to the right setting. I had to run it on a good bit to keep it running with all 3 things unplugged, but as I backed it off the motor responded and I stopped just before it died. Hooked it all back up and she cranks at 200 degrees now!
Thank y’all so much for your help! Now I just need to get the ECM mounted back in its hole and my original distributor back in (with new TFI lol).
toddz69
Great news!
I always like to read along in these threads - hoping to learn something.
Todd Z.
SC74
SC74
Great news!
Todd Z.
I love learning too, and I learned A LOT on this one.
I think the main thing was that I had to re-learn the computer to the new parts - like GT40 intake, AFR heads, and the cam - all things that would require adjustment to run better.
