66 brake light switch
NC-Fordguy
Bethel/Greenville NC
Guys...
Bought my second bronco a 1966 model with 89k original miles
One of the first things I want to do is get it to stop!!!!
I'm going to do a GM front disc conversion and I am wondering what to do with the brake light switch as the single resevoir master cylinder will get replaced.
Searching the forums I'm seeing two solutions. Some sort of tee fitting on the brake lines or refit a newer pedal switch
What's the better way to go???
Viperwolf1
electron whisperer
I think the late model pedal switch is a better way to go. A switch in the line will need some volume of fluid to activate, make your pedal feel less firm and it will be a potential leak point.
jedblake
Boulder City, NV
x2 on the later model EB pedal (anything post '66). I did mine this way and have had trouble free operation.
I ordered an aftermarket switch from Tom's and it was junk (only $12 though). I had the best luck going to a local junkyard and cut out a factory brake switch from an Econoline van. The OEM switch is twice as robust and is insulated in rubber with pigtails for you.
You may also want to splurge on the power booster, bracket and valve a little expensive but well worth the cost. I kept my factory hard lines with the intent of replacing the lines front to back one day, but so far not a problem.
You could also go to the other style of mechanical switch that uses a standard plunger. You could then make some sort of mount for it so that the plunger either hits the pedal, or mount it to the pedal so that it hits something else when it moves.
Lots of Fords and GM vehicles used this type. I think my '83 F-150 even used it.
Desert Thrasher
I use the hydraulic switch and have no issues with it. It works flawlessly. I tried using the later stock style switch for a long time but it never worked right.
I have hydroboost brakes and the pedal is nice and firm.
KManuel
Cape Cod
X2 I did the same and have NO issues with the brakes.
SteveL
Huge chevy guy
Hawthorne ca
I also had problems with the later eb switch and the 66 pedal assembly. it never wanted to work right. I ended up using a 78 switch(push button type). I had to fab a little bracket out of L metal, but it works great.
