My 74 came without a horn and to further complicate matters, I switched to a 75 steering column and steering wheel a few years back. My question concerns the horn switch and how it connects to the 75 steering wheel. Under the horn pad on the steering wheel, I have two wires with connectors/terminals on each but only have one terminal on the steering wheel. Do both leads connect to the same terminal on the steering wheel? I also have no power coming into the column horn wire (blue yellow) and can’t seem to find the horn relay under the dash. I’m guessing power comes to the relay and then out to the horn switch or is the switch in the pad completing the a circuit as a ground?
Everything works on my bronco but for the horn so I’m trying to track this down.
Tim
Tim
