- Jun 13, 2012
- 796
back at it again. here is what i have pulled out of the 96 explorer so far. makig sure i have everything i need before i call the junkers to come haul it away.
engine
transmission
trans cooler (not sure if i can use it?)
engine wiring harness
transmission wiring harness
the main harness with head lights, the three plugs that go into fire wall, all fuse and relay boxes. basically stripped all the wiring from the explorer.
computer
computer bracket
Inertia / Fuel Cutoff Switch. i cut the wires as low as i could and removed the switch. do i need this for my build?
what about the obd2 plug. i am not sure if i need this or not?
how about the fuel delivery system? do i need the pull the explorer fuel pump or will this depend on what fuel tank i go with?
is it worth keeping the truck around for anything else that can be used in my bronco?
thank you in advance.
cheers
engine
transmission
computer
computer bracket
cheers
