Explorer swap more questions
ThorMike
I’m not working on a bronco but 1967 mustang with t5 manual. Watched all the videos and read all the threads I could find and still have some wiring questions. This seems to be the place to go:
1. With manual why would I need to keep vss if I’m using a gps or cable speedo?
2 same with the reverse lights why would I keep these wires?
3. Egr delete- do I just backtrack the large plug and delete wiring or?
4. Why use the Solonoid hot side vs having a central positive lug lug and just a trigger to the starter?
5. Has anyone used forscan or other to code for the manual trans?
The engine is a 97 so no PATS. I didn’t get the trans harness and can’t find a diagram of that connector with the pins to help speed the clean up of that part.
Galt72
I originally installed my explorer setup with manual zf5 without the vss. It would stumble at idle. I installed the vss the problem disappeared.
T
ThorMike
Did you just plug it into the speedo port on the trans or just left it plugged in?
EFI Guy
TheEFIguy@gmail
BFE
1. To prevent stalling at stops. Just use the VSS in the T5.
2. You don't. Use the existing vehicle's wires.
3. I'm not touching that.
4. If your question is "Why should I keep the fender-mounted solenoid?". The answer is that it's an easy to use power lug. But it also reduces the load on the ignition switch. When Ford removed the fender-mounted solenoid, they added a relay and used 10awg wire fused at 50 amps to trigger the starter. You can, in theory, do the same. Just don't expect your current wiring or ignition switch to handle the load of triggering the later starter.
5. No, Forscan can not program that era of PCM. I do recommend reprogramming to get rid of the auto trans functions at a minimum.
6. I don't have a pinout of that connector, but you can email me for the factory diagrams.
T
ThorMike
great thank you, i have been watching your videos and they are amazing. this helps immensly!
the wiring part was overhelming but watching and starting to clean up the harness has not been bad, just need patience.
Jedeka
Is this what you need?
T
ThorMike
Thanks I think I’m getting there I ordered a trans harness to help chase the VSS and ob2 wires down. I think I’m going to start stripping out the rest of this trans wiring and jus make a plug for the vss
