So I’ve almost completed my Explorer swap. I’m running the stock fuel pump. Do I need to install the tank pressure sensor as well or is that only an emissions things?
Pictures would be helpful. What sensor are you installing? Can't determine if you have a return system or returnless. Does the fuel rail have two fuel line connections?
Its for your EVAP system Its used when when OBD II runs the monitor to check for a leak in the system with out it it will set codes EFI guy and some programing can deal with that .
