joshd1971bronco
All,
I did a search and surprisingly didn't turn up much. I have a '76 with the stock "Y" style linkage. I want to convert to a "T" style linkage. I have found a vendor (WH) that makes custom 3 way adjustable T-style linkage that is a bolt-on replacement for the Y-style - it fits the tapers in the knuckles and in the pitman arm.
Of course, I want to run a tie-rod-over setup so I need to ream out the top of the knuckles with a tapered reamer. The guy I talked to on the phone said that I needed to buy the tapered F-150 sleeves to insert into the BOTTOM of the knuckle after I ream out the top of the knuckle. This doesn't make complete sense to me. I realize that the bottom of the knuckle will now be tapered along with the top, but I don't see how inserting the F-150 sleeves fixes this.
Any insight or help on what to do about the BOTTOM of the existing knuckles is appreciated.
(Also, any input on whether there are any CONS to doing a TRO conversion is appreciated as well - I have a trac bar riser bracket and stock pitman arm, 3.5 inch susp lift)
