Just got from alignment shop.
Left Front.
Camber -0.2 deg
Caster +4.6
Toe .38 deg in
Right Front
Camber -0.1deg
Caster +4.2
Toe .36 in
3" SL with no body lift, 12.x33 tires.
I had a death wobble when applying brakes and after changing tire pressure, checking for worn issues, etc on front end I finally just replaced the tires. I had the General grabber that seems to have a wide flat surface to a MT style tire and it seem to help with the braking DW and being all over the backroads so far.
Seems to drive pretty good it feels like maybe a little bit of movement going down the road.
Left Front.
Camber -0.2 deg
Caster +4.6
Toe .38 deg in
Right Front
Camber -0.1deg
Caster +4.2
Toe .36 in
