Another 4R70W question.
broncokak
To add to that question (reads slightly hi-jack this thread) what are people doing about converter lock up? Anyone adding a switch or just letting the computer handle it?
I was thinking of using the 4 way flasher switch on my soon to be new to me tilt steering colum seeing how the 68 4 ways are on the dash.
OD off was done with a switch on the center console (along with the secondary shift table)
Lock up is handled by the computer but an added lockup button is added under where the clutch pedal was. So I could lock the convertor at slow (and steep) climbs to keep the convertor cool without having to keep the motor reved in too low of a gear. Waterproof marine pushbutton from the lockup solenoid to ground.
does the Baumann controller take care of this??
Yes it does. The Baumann has an input for the OD off. You can set it to either be a momentary pushbutton or an on/off switch. The software can handle either way with the change of a single setting.
As for the convertor lockup, I was wanting to lock it at (near) idle conditions to eliminate all convertor slip. Make it pull like a stick shift without the fluid coupling. So I added an extra (and most people will not need or use) button that I could mash with my extra foot. I would do steep hill climbs at idle that lesser trucks would be flogging hard at. I also used it on some long (couple mile) rocky but not so steep climbs. First gear (high range) would rev the engine needlessly but would get into the coupling stage of the convertor. Second high range would just be working the convertor too much for my liking. Speeds were slow enough that the convertor was not into the lock up logic. So I would manually intervine, second gear, convertor locked, idle along at 1200 RPM (instead of 1900 unlocked) and not build heat in the trans.
broncokak
So how does the lock up converter like that? Is it going to hurt it at all? I was telling someone about this idea today and they thought the lock up mechanism wouldn't hold up very well.
Locks up when the solenoid changes the pressure to the lockup clutch in the convertor. The convertor is often locked up at full throttle while towing, so it can handle full engine power, for what I was doing I was only idling so less stress.
broncokak
I guess that makes sense. I don't have a lot of experience with lock up converter so it's going to be a learning curve all the way. Thanks for the info.
krisbassett
krisbassett
I can def see where being able to lock the converter would be handy!! Being able to keep your tranny cooler is always a good thing!!
