Another 4R70W question: linkage
kholding
Las Vegas, NV
Alright, I am getting ready to install the Winters shift lever onto my 4R70W and am not sure if I need to remove the pan to remove the original shifter mount? It seems like it is pretty tight so I figured I would ask before I break anything. Looks like Winters provided me a new mount/linkage and want to get it in right.
I'm sure some are laughing but this is my first time with this and want to do it right. Thanks.
Viperwolf1
electron whisperer
Yes, the pan needs to come off. There is a small pin holding the shaft in, right where that groove is.
Amac70
ME
when you remove pan pefect time to change filter and add a drain plug/temperture sending unit hole to it.
COBlu77
Arvada, CO
No need to drill a hole in the pan of a 4R70W. There is a pressure test port just to the left of what your picture shows that most people use for a temp sender. My B&M temp sender screwed right in. I beleive it's 1/4 NPT.
kholding
kholding
Las Vegas, NV
Thanks COBlu77. I know they say the "best" way to measure trans temp is at the bottom of the pan but I'm sure the 2 options have to be close.
Viperwolf1
electron whisperer
Unless I'm mistaken the 4R70W already has a trans temp sensor and the temp can be displayed on the Baumann controller.
kholding
kholding
Las Vegas, NV
Next problem. The rear bracket will not clear the front driveline. It's not even close! Tried bending the bracket slightly and it cracked right away. Do I need to make a custom bracket? Should I be worried that my shifter cable is that close to the front driveline? The last photo has the bracket on the driveline for reference.
Rox Crusher
I assume the bracket mounts to the two bosses on the tranny ?
The other thing I ran into was clearance between the driveline itself and the pan.
I ended up getting a new shaft made out of smaller diameter material.
PS.......when you have the exhaust done, make sure they cycle the shifter through all the gears.
kholding
kholding
Las Vegas, NV
Thanks Rox Crusher. Good advice. I'm mocking up a plate now that I will have to make to keep the linkage in a safe spot. The original bracket actually bolted to the 2 pan bolts furthest back putting the cable right where the front driveline is.
kholding
kholding
Las Vegas, NV
Doesn't look like I am going to have enough clearance with the Winters arm? It sits right on top of the front driveline. Anyone use this shifter on the 4R70W with success? Can you show me how you ran the linkage? Thanks.
kholding
kholding
Las Vegas, NV
This is not the final bracket, just looking for routing options that will not contact my front driveline or bind the shifter. It would most likely need to an "L" shaped piece to keep from moving (using the the other open bolt hole just in front). I was hoping to get a straighter pull on the arm, but can't really find room any other way? Anyone see any potential issues running it this way?
Amac70
ME
If you look in my gallery you can sort of see how i did mine i moved all the attachment points for the cable to the inside next to tranny and cut and welded the winters bracket closer to the pan, also had a custom made smaller diameter drive shaft made.
and yes the optishift will tell you the trans temp but if you have aftermarket guage in dash already your going to need to put that probe somewhere in the pan.
kholding
kholding
Las Vegas, NV
Danwheeler: my shifter cable comes from the rear which is making it a lot harder because there isn't much room around the front driveshaft and D20.
Amac70: Mine looks like it has even less room than yours. I looked at modifying the original bracket but it looked too close to me.
Here is a quick plate I just drilled out to see what clearances I would have running it with a straight pull. Everything looks really tight. The pictures show the trans in 3rd gear (about 1 7/8" clearance from the front driveshaft). I think that might be a little too close for the driveshaft for me. The other option was flipping the bolt on the shifter arm toward the pan but then it causes the cable to terminate right at the yoke (another scary option).
Amac70
ME
would you have more room if you moved it to the inside like mine. my cable is right up next to the pan mounted between the pan and the bracket not on the outside of the bracket like you have it. i cut and modified the winters bracket to do this.
