Another 4r70W conversion question
desertguy76
Norco, California
I have searched this forum up and down and everybody has different original set-ups leaving me with a couple questions. I have a stock early 302 with holley sniper, 3 speed trans and a T shift dana 20 currently. I have started sourcing parts to control costs and then I plan on having the conversion done by a local shop once I have everything. I have never attempted anything like this and want to make sure it is done right.
Parts I currently have
- Flaming River tilt w/ column shift
- Lokar linkage
- Lokar dip stick
- wild horses 1" body lift
Parts needed and questions
- Planning on getting a core from car-part to have rebuilt
- Adapter- There seems to be two different part numbers is this adapter the one I need? https://shop.broncograveyard.com/AODE_4R70W-Swap-Kit/productinfo/11325/
- Do I need a clocking ring?
- Will a remote oil cooler with fan be suffice to keep trans cool? I don't want to change the radiator out yet because eventually I want to add a serpentine kit. I thought it may be beneficial to change to reverse inlet/outlets to make for a cleaner install at that time
- With the T-shift is there a benefit or need to go to twin sticks?
- Is baumann still the most popular controller?
- What flex plate do I need?
- Am I missing any other part that I should provide vs. having the shop source?
Thanks for any help you can provide I hope to source the remainder of the parts in next couple weeks and have complete to enjoy by summer.
samamarshall
There are two versions of the adapter - the wildhorses site has a bit more info on it:
https://www.wildhorses4x4.com/produ...dapter-converter/Bronco_Transmission_Adapters
https://www.wildhorses4x4.com/product/Ford_AOD_to_Dana20_Adapter/Bronco_Transmission_Adapters
Since you're rebuilding get the adaptor kit with the new main shaft, no 'clocking ring'. It's a simple swap of the shaft during trans rebuilt.
If your donor was low mileage and working, make sure it's a 4WD version and you can use the other kit, and you trim off some of the existing main shaft.
duffymahoney
I have the quick shift 4. Works awesome, I went the easier route with cutting the spud shaft and clocking ring. I didn't change the flexplate. I didn't rebuild mine, it came from a working explorer, so I just ran it. No real issues so far.
D
desertguy76
Norco, California
Ok so the link I provided is correct with a rebuild? It’s 100.00 cheaper vs.wildhorses for some reason and I won’t have to pay sales tax. I plan on buying a 4wd Fire but want to have it gone through just so I don’t have to worry.
WILDHORSES
USA
Knowing how much WH likes customers and customer service I would give them a call and see what they can do for you.;) I have these on the shelf. You could have it by Tuesday.
Jim
Flexplate will need to be 28 oz-in C4/AOD/4R70W 164 tooth version. 11+" bolt circle.
Do NOT get one for a C6/E4OD, they have all the same specs except the offset is slightly different and wrong. It will bottom out the pump and push the thrust bearing away in the engine.
The rest of it look like standard choices and options. The US shift controller works nice, should adapt to the EFI just fine.
The cooler, I really like to see an in radiator cooler hooked up. It will cool when you don't have the airflow. There is just so much good for using one. If you are going to run just an oil to air get a big one, get it in front of the radiator, don't program for short shifts and try to get lots of convertor lockup to keep the temps under control.
D
desertguy76
Norco, California
Thank you
bronco italiano
desert guy,
-You will love twin sticks on your t-case.
-If using dana 20 get the no clocking adapter
-I have a remote cooler with thermostat fan control and large filter. I am very pleased.
-I also had a edge build me a torque converter. If your engine has been dynoed you can get a real nice TC built.
-I also had my trans builder machine the drum for an extra clutch.
-I used baumann kit/controller.
D
desertguy76
Norco, California
desert guy,
Thanks for response. Is the no clocking adapter the one I attached link too?
jagbucket
i read the info on the bronco graveyard adapter and states that the overall length is only changed by 3/8" is this a new part? all the info i have seen from other vendors has 1 1/2" for this style and 3" for the clocking ring type. Jeff's state that driveshaft length will remain the same.
D
desertguy76
Norco, California
I’m not sure but I only saw one on advanced adapters website and it’s the same part as bronco graveyard’s. Nobody else has the part numbers listed.
