Another 4r70w thread
MonsterBIlly
So I am on my 4th trans in 4 years. I have had the same shop rebuild it twice and warranty it once. So this time I ordered a new one from Monster Transmission. Their were great to work with, their customer service is awesome and they keep you constantly updated. However!
I had made the order over the phone. I gave them all the info as was very specific. The trans snowed up today and something seemed off. And it was. they sent me a 97 model rather than the 98-2003 I had specified. There are only a couple diffs. Mainly the shift solenoid plug is different, 7pin rather than a 9 pin. This can be corrected easy with a slight rewire or a partial harness from US shift. The other though is the length of the output shaft. The 97 shaft is 1 inch too long. It wont fit let the atlas contact the trans. the size and spline count are the same. Can I just cut the shaft 1 inch? if so what is the best way just us a grinder or gig up a chop saw.
I take partial blame, I should have looked over the invoice in detail and didn't. John at Monster was so thorough and even repeated the year (98) to me over the phone. I know by now not to assume anything but I did.
I did email them and I'm sure I will hear from them tomorrow
I'm so over this transmission shit. It almost make me want to sell it and be done. However I wont. I'm just venting... again.
73azbronco
Find a weld shop with a metal band saw? The kind that articulates down as it cuts, not a stand up like in wood shop.
bigmuddy
Marthasville Missouri
I cut the end off of my last ZF with a cut off wheel on a 4" angle grinder being careful to not overheat the shaft and to try and stay as even and perpendicular to the shaft. There a small margin of error I would believe.
JSBX
I cut mine with a die grinder with a cut off wheel. I found a piece of pipe that fit over the shaft cut it to where there was 1" of shaft sticking out after it was slid as far as it would go on the shaft using it as a guide to cut the shaft straight. Then cleaned up the splines with a 3 corner file. Good luck.
bigmuddy
Good reminder after cutoff, I took a flap wheel on my grinder and eyeballed a chamfer on the shaft. Still works today, no issues at all.
I do like the pipe idea as a guide though.
