Another clutch rod question
BRONCITIS74
I did the 1" WH body lift. When I got the truck back together I tried to move it, but when I let the clutch out nothing happened. I just sat there. So I got a WH 1" extended adjustable clutch rod. I tried to get it close to being 1" longer than the stock rod. Just tried to move the truck and the same thing...nothing happens when I let out the clutch. I tried making the rod longer and shorter and adjusting the bullet rod under the truck and it still doesn't move. Has anyone else had this happen? How did you fix it? By the way, happy 4th to all. Thanks. Mike
Timmy390
Conway, AR
Are you sure the transfer case didn't get knocked into neutral while putting the lift on?
Tim
BRONCITIS74
BRONCITIS74
My Bronco moves and drives!!! Thanks so much. I sorta feel like a dummy, but it isn't the first time and I know it won't be the last.
