trophybass
Ok here we go again, i've got one of BC Broncos OLD 25 gal tanks, I have no valve and no switch. I have the sending unit grounded to the body and the other wire going to the back of the guage. Now the problem is that my fuel guage was barely moving(stayed at E) with about 10gallons(1/2 a tank of fuel), so i decide to switch the guage cluster to a different one to see if it was the IVR well now i have about 15 gallons in it and it's only reading 1/4 tank. I went to the gas station and put 5 gals in it and it moved up a little but it wont go over 1/4 tank. Does this mean its the IVR or the sending unit? I disconnected the wire to the guage and grounded it and it pegged above full which is info i found in another post but i still dont understand which it could be. When i put my ohm meter on it(before i installed the tank) the sending unit ohms would change when i moved the float so i assumed that it was good. Where do i go from here. Oh yeah running out of gas SUCKS i was just of that today. Thanks, Alex
