I have spent allot of money trying to get my Bronco to drive better and have made improvements but it took a step back yesterday and started to wander again.
I have replaced and rebuilt everything except my steering shaft/rag joint and I have also not rebuilt my steering column.
A rag joint is $40 but how do you know if it or my lower shaft that connects to the rag joint is bad or bent?
My steering shaft u-joint has no visible play in it.
Yesterday I had my tires balanced using a Road Force balancing machine. I but the wheels back on then had my wife turn the bronco from lock to lock in the drive way to check for binding and clearance. She put a bit of pressure on the rag joint in doing this. I then took it out for a short ride and it drove worse.
I am wondering if the forced lock to lock may have made the rag joint fail more.
There is no visible play in the rag joint but can you tell by these pics if something is worn out or in need of replacement?
I have a 2 inch body lift and it does put a bit of a bend to the rag joint because of this. If I need a new joint I am leaning to buying a double joint after market shaft for $200+.
