Is there any way to bench test the oil pressure gauge itself? I hooked up a mechanical one & it has good oil pressure. I replaced the sending unit & checked wire continuity & it’s good. My only guess is the gauge. Any other thoughts on this? All the other gauges are working.
Of course there is.
But the question is more about what's actually happening. Is your gage moving at all? Or pegged full? Or stuck somewhere? Regardless, if you want to test your oil pressure gage, you need to understand that the instrument consists of an Instrument Voltage Regulator, a Movement, (also named the Gauge) , and a Sender. It is rare that anyone wants to test their "gauge" when they really want to test their "system."
But you need to know that the oil pressure gauge runs at 5 Volts of pulsating DC. And it drives that 5 Volts thru the instrument, and uses a variable ground at the block. The Ford resistance values are 10-73 Ohms. So a 10 ohm resistance gives you "max" and a 73 Ohm resistance give you "min" The halfway point is 24 Ohms, which is a common resistor value, but you need a 6 watt power resistor so it's harder.
@Jdgephar is giving great advice if you want to test the instrument function. Ground the sender, and watch the instrument sweep to "max." But if you want to test the accuracy of the instrument, You want to test it at 23-25 Ohms. I use the tail light filament from an 1157 incandescent light bulb from a tail light socket. The tail light fllament is about 23 ohms, and will handle the power output of the IVR. So if you put the 1157 bulb between the sender wire and ground, it should go exactly 1/2 way.
