best performing engine for a bronco?
broncnaz
That's what the variable valve cam timing is for... It's like having an RV cam and a big race cam in the same motor. The only way Ford could make a better engine honestly would be to make that variable cam timing and lift.
All true except the numbers still only show up at the upper end of the RPM's. Ok one of the engines has turbos which will help out its smaller displacement. And these engines are pushing vehicles that are a little more areodynamic than a bronco.
If I remember correctly most of these vehicles have about a 4-1 first gear and use 3.73 gearing. Part of the reason is to get the engine into its RPM range.
Im not against these engines or there technology but I think people mistake the numbers and hype and believe it will be a better engine for a bronco. Kinda like the people who ask about the 210hp SOHC 4.0l sure it has more power than the early 302's but again that power is in the upper RPM's. My 03 ranger has 4.10 gears stock tires and gets 20mpg on the hiway but has nowheres near the raw torque that my 73 bronco has. If I swapped it in I highly doubt the bronco would be as enjoyable to drive or get better mileage than what I currently get. It just doesnt have the power where its needed.
Colorado75Bronc
Colorado Springs
The technology for vvt and variable valve lift is already there, the new jaguars and landrovers I work on have 5.0L engines that have both and they're built by ford
KyleQ
351W with Mustang injection and you get great low end torque and mid range HP and driveability of a modern car.
Colorado75Bronc
Colorado Springs
But I agree with the majority, do a mild 351w w/efi, overdrive trans and the right gearing for your size of tire, that's the best option, I can't wait to get mine swapped in
jlylec
So I just allowed myself to accept the fact that my 5.0 needs to be rebuilt. Reading this it sounds like I should consider a swap to a 351W with EFI (truck will is 80/20 street/trails, C4). I don't have the tools or experience right nowto do a rebuild or swap myself so am shopping this out to a local ford guru I met. I do plan on helping and being involved so I can learn and plan on long term doing the majority of my own wrenching.
The most obvious options I'm considering are:
1. just rebuild the 5.0, install Explorer serpentine conversion I already bought, and leave everything else the same (2 barrel carb, stock heads, manifolds, etc);
2. rebuild the 5.0 with serp conversion, new heads, headers, EFI?, ?
3. swap to a 351W with EFI
Obviously there are a thousand different ways to skin this cat, but those seem like 3 of the most obvious. Any ideas on what I should expect on cost for each? Option 2 seemed like the way to go to me before I read this, but I haven't even gotten a quote on 1 yet so who knows! Is it worth buying a new 351 or would you just source a decent one in a junkyard and rebuild it? Clearly I have no idea what I'm getting into here!
I do agree with the posts above that while the Coyote sounds sexy, even if I wanted to spend that kind of money I wouldn't because I bought the rig to be simple and something I can work on myself in the yard or the mountains.
Any advice is greatly appreciated and sorry if this is a hijack but it feels like it's in the same vane!
KyleQ
If you want more power and torque while wanting a fresh engine I would still suggest a 351W. The Explorer Serp fits, Mustang injection works perfect and you don't have to use performance parts to get what you want out of it as compared to a 302.
I would source a junkyard 351W - mileage doens't matter. I got a 351W out of a van with 180K and it was perfect besides two stuck rings from sitting. Still had cross hatching on the cylinder walls - I had it honed and new bearings thrown in as it was apart. I tossed on GT40 heads and the power difference is amazing-
bronconut73
Yea, what he said.
jlylec
Any drawbacks on the swap to 351? I guess size and fuel efficiency are the only real negatives right? I'm not TOO hung up on efficiency but if we're talking the difference between 15MPG on the 302 and 5MPG on the 351 maybe i would be.
I've heard they're a bit tighter fit. Any issues with specific headers, 4x4x2 box, etc.?
Only other consideration is cost I guess. How much did the 351W at the junkyard run you? Should it cost about the same to rebuild once I own the block?
Sorry for all the questions! I really do try to research and read up on all of this myself, but sometimes it's easier to just run with a train of thought! Thanks guys!
jlylec
Yea, what he said.
Oh and I think I read somewhere about 351s eating up C4s or 9" rears....true? I probably need to rebuild both of these on mine anyway but I'd hate to do that and then just destroy them again with the beefier engine.
73azbronco
Rearend and tranny only care about how much power you inject. A mild 351/stroker is OK with a C4, anything more and I tend to think a manual tranny would be better, the stock rear end should handle anything up to 400HP/tq BUT that depends how you hit the throttle: slow, no problem, drop the clutch: problem.
Timmy390
Conway, AR
No way on the 9, can't speak to the C4
The Ford 9 is dang near bullit proof. Every car on the track at a NASCAR race has a Ford 9 under it.
Tim
ugly74
Bronco abuser
Colorado
Tim
But they arent running 28 spline axles either. Im surprised that mine are atill holding up.
I am starting to get a squishy 1-2 shift out of the C4.
, and it has less than 2000 miles on it
Timmy390
Conway, AR
You got me there. Breaking axles is different in my book from breaking the 9. The 9 did come in several configurations some stronget than others (open, two pin and one pin trac loc, 28 and 31 spline, etc). Most (if not all) Ford cars of the 60's-70's with a 351w got 28's. Heck, my 69 Mach 1 big block (390FE "S" code) car came factory with 28's. Ture, tires have gotten bigger/wider over the years but I think we can both agree, the 351w isn't a rear end killer meaning if you drop in a bronco, the 9 isn't going to give up it's milk and be killed due to it's output.
Tim
svobronco
My vote is for a 4.5L PowerStroke. I want to see someone do one.
Revelation
After my recent F-150 purchase I can say An Ecoboost with the 6sp auto would be a beast in Bronco.
Mountain Ram
Recovering Masshole
Abingdon, VA
So I have been told and read a bunch that the GT40 heads are the choke point for the 302... With the 351 having more cubes and moving more air... How are they better than stock 351 heads when they are a drag on a 302?? The mustang guys curse when they hear someone putting them on a 347...
Todd
Todd
I think you are mixing up your heads a little bit.
The 302 nad 351 heads are essentially the same (the first couple of years the 351 got slightly larger valves, finding a set of those 40+ year old heads that don't need a total rebuild just isn't common any more).
The GT40 heads were the late model factory high flow heads, typically picked off soccer mom Explorers. By no means are they the greatest head ever, they are just the best of the junkyard heads that can be found in large volumes and still in good shape.
Mountain Ram
Recovering Masshole
Abingdon, VA
I admit- I dont know much about the 351 heads...
I have a good, running '96 explorer 5.0 that I have torn down to eventually replace the 89 Gran Marquis 5.0 the PO installed that is making noise. Although the 96 motor is in very good shape... I can't leave well enough alone and have thought about stroking it. If the GT40 heads are good enough for the 351... What's wrong with using them on a 347? Are there better heads- Yup- for both motors... But if they breathe enough for the 351, they should do just as well with a 347.
I guess I need to gain some understanding of fundamental performance motor design. Even on the Horsepower TV show today- they showed how a better breathing 351C head (2V vs 4V on the C motor) was not better for a street motor, dropping both torque an HP. Larger heads typically move the power up in the RPM range- exactly the opposite of what I am looking for in my street Bronco on 37s.
I can see where a 351 as a base would be lower cost- no bore and stroke changes unless the motor needs a crank and bore cleanup. You are already starting with 350+ cubes... BUT I hear of alot of cooling issues with the bigger block. May be a bad perception on my part- but I still hear and see it. Not to mention a few other minor fitment issues.
What I really want to know- can you build a 302 based stroker and design it around the needs of a Bronco owner with oversize tires... and what is that formula? What will a 347 with GT40 heads do and what kind of cam should you throw in it to maximize torque and HP in a driveable RPM range (1500-5000rpm??)??
Todd
