Bronco Suprises
Aaron68
Taylorsville, Utah
Bought my bronco when I was 17 (6 years ago) despite my dad telling me not to. Got it home and pulled out the orange "shag" carpeting to discover the PO had layed TAR in the entire tub! Thick too, almost 1/2" in some spots. My dad just laughed at me as I sat for weeks pouring Paint thinner on the tar and scraping it off! I am now happy to say though that my dad is fully jealous of my bronco and the way it has turned out.
SACHEM
Back From the Dead
HA HA, My Dad told me not to get one and has since decided that he needs one as well. Mom isn't to keen on him getting a Bronco, But I'm sure he'll get one anyway. When he does I'm sure he will here use all of the stuff in my spare parts bin. I guess that is what I get for forcing a Father son project on him. ;D :cool:
68beast
Covina, Kalifornia
I liked the fact that when I went to go buy a serpentine kit from BC for the 351 Windsor in my bronco, and Chuck tellin me "The water outlet isnt like that on a windsor!?!" Turned out I had a Cleveland. I think that was a rather nice suprise since it was allready nicely built and installed in. But nasty in that its harder to find parts for.
Arnold'76
Cincinnati
Like many others I discovered the ever popular road sign floors. When removed and put together they read END CONSTRUCTION. Maybe that was a sign I should have paid attention to. Also discovered the wire nut cluster in the drivers side wheel well, and someone had stolen the original 302 and replaced it with a 351W. Damn the luck!
LostInTheSouth
Ramstein
My po had the nack for wiring he would use 3 pieces of wire to go 1 ft. He also put the battery on the wrong side for some reason.
BroncGuy7710
Louisville Ky
I found a bunch of oiley old rags between my hardtop top and the cross pieces on it:) guess he was trying to keep rattle down. I also found a roll of scotch tape (yes the plastic roll included) tucked under my dash. and my kick-down linkage was cut and then lengthened with the head of a screwdriver.
:eek: :eek: :eek: Tyler:eek: :eek: :eek:
SeaBiscuit68
Tacoma Wa
My bronco sat for 12 years before I resurrected it and brought it home. It turned out to be full of hornets nests. I tried everything I could think of to get rid of them. I pressure washed every nook and cranny I could find. I even squirted bug killer into crevices and such. Still they keep turning up and at very lousy times like on the freeway. I hate hornets!
brian72
Early Bronco Student
have you tried putting the bronco in a small garage and then setting off 4 or 5 bug bombs.
hakstooy
Alexandria, VA
When the PO replaced the floorboards, he "forgot" to seal the front edge of the drivers side panel. There is a good 1" gap up under the firewall insulation where the new panel should meet the firewall.
mtkawboy
Billings Mt
Bronco Surprises
My first one was a 69 wagon the former owner had been spitting sunflower seeds into the back of for god knows how many years but it was 2 inches thick! The rear seal leaked out about as fast as you could pour the oil in. it had a burnt exhaust valve which had been run so long it burnt the seat out and cracked the head. I hope the new owner doesnt mind that it now has one stock head and one 302 low compression van head on it. I was dead broke at the time 20 years ago. It ran fine that way though. I did put a new rear seal in it.
evil69
fawkin classy
Athens, GA
I bought mine from a buddy who had rolled it.%) %) %) On the street going 20 m.p.h.! He replaced the fenders and such, but had the windsheild frame welded with flat stock to "brace" it. Then he spent $85 having the glass shaved to fit the cockeyed frame. So with new glass, welding, shave =$275.%) Have yet to get to body work yet. The welds are nice too, right along the hinge. Or at least what was the hinge before he lowered it a couple times. He said the first time was a little hard. Wonder why.
cjjhalfcab
Oologah, OK _
I had some living inside my passenger side rocker panel. But it has been pack rats that have done the most damage to mine.
C
Case
mice did a number on my 72 when it sat for about 2 years. They tore up everything and made nests everywhere.
byrddog
Broadway, VA
Some PO "fixed" the entire floor of my 74 by covering it with stainless steel. I don't know what kind of adhesive he used. Guess I'll find out how well its stuck in there some day. He also painted right over the SS. Yeah, that didn't work so well.
Retro69
PO wired the stereo, driving lights, fog lights, and aux heater with the same gauged red wire. Under the dash was a cluster of red wire.
akafrankcastle
Kansas City
I found plenty of caulk and body filler stuck to an empty Marlboro carton in one place and a McDonald's cup lid in another.
It was on it's 3rd set of "floorboards". The originals were still in place with sheet metal over the remains of those and tin over the sheet metal. All of it sealed with caulk.
mrcat88
VacaVILE, CA
I have one hell of a list....
The best one was CB antenna holes in the hardtop....both sides...which were patched with roofing tar, aluminum foil, and round electrical plates.
The PO didn't know jack about installing the 351W, so instead of putting on the 302 waterpump, he took the radiator out and had the ports switched to opposite sides...%)
Now, because he switched the ports on the radiator, the bolts for the power steering box were in the way....so he took a big hammer, and did everything he could to destroy the frame where the PS box bolts on.
I don't think there was a single tight bolt or nut anywhere in the steering system.
Fancy wood dash...with a nice big hole for something like a stereo...promptly ripped out.
Of course, the usual hack job for the shifter.
Nice, big, slice-your-hand-open hole in the hood, with a spiffy trans am hood scoop rivited in place over it...you know, the ones with the ridge running down the center.
he ruined the body by hanging a 33" tire in the stock rear tire carrier....Just FYI for those that don't get it....that tire carrier bolts to your body, and should never have that much weight on it...you get what I have, Bronco 'body' lean. The whole corner of the truck is about 1/2-1" out of wack.
I think I could make the list longer....but that's all I remember off the top of my head.
OOOO....one more! he cut the brackets off the rear seat, had some 1/2 inch plate aluminum wheel stops fabbed up, and used those as new "brackets" for the rear seat.
Mrcat88
I don't the PO knew what wiring was....I think it was like "hey, if it sparks, I'll get power out of it!"
Repairs? What repairs? I don't think my truck has ever seen repairs!
fox
well working at a 4x4 shop u see everything, we say a guy that had welded two pieces of angle iron together to make a box for his pitman arm, ya we told him that he could buy the part from us but we weren't about to touch that abortion. It shure makes you wonder what 500 dollar piece of crap is gonna brake and run head on with you in the middle of no where...........
