- Nov 3, 2003
- 51,651
I will reiterate, that it’s usually not a good idea to pull that last quarter-inch with the bolts.
Yes, some people do it successfully because the snout of the input shaft is lined up just almost correctly with the pilot bearing. But most of the time it puts too much stress on something.
Luckily, or unluckily, our bellhousing’s are cast-iron, so you usually do not break an ear off of a bolt flange/boss on the bellhousing.
The bad news is that the bellhousing is so strong, something else usually doesn’t fare so well.
Because it’s so close to fitting, you think that everything is lined up. But that can be misleading as it could very well be the tip of the shaft touching the edge of the pilot bearing.
The plastic alignment tools are actually pretty good, but they’re not perfect. There is some leeway with the clutch disc moving up and down.
So while you may already have the splines engaged (most likely since you’re only a quarter inch away) you may not have engaged the pilot shaft yet.
Many a recalcitrant engine/transmission meeting has been solved by releasing the clutch pressure to allow the disc to float.
Many…
Many…
