Broncoski ( My Build Thread)
I will reiterate, that it’s usually not a good idea to pull that last quarter-inch with the bolts.
Yes, some people do it successfully because the snout of the input shaft is lined up just almost correctly with the pilot bearing. But most of the time it puts too much stress on something.
Luckily, or unluckily, our bellhousing’s are cast-iron, so you usually do not break an ear off of a bolt flange/boss on the bellhousing.
The bad news is that the bellhousing is so strong, something else usually doesn’t fare so well.
Because it’s so close to fitting, you think that everything is lined up. But that can be misleading as it could very well be the tip of the shaft touching the edge of the pilot bearing.
The plastic alignment tools are actually pretty good, but they’re not perfect. There is some leeway with the clutch disc moving up and down.
So while you may already have the splines engaged (most likely since you’re only a quarter inch away) you may not have engaged the pilot shaft yet.
Many a recalcitrant engine/transmission meeting has been solved by releasing the clutch pressure to allow the disc to float.
Many…😉😁
gnpenning
Bronco Slave
Follow Paul's advice.
If you need to you can put a breaker bar or rachet on the crankshaft bolt and turn it while trying to mate the motor to transmission. A helper makes life easier.
Is the transmission/transfer case supported? If so how? You may have to adjust the angle?
Looks nice, now isn't the time to make any expensive mistakes. If needed walk away and take a deep breath. You have got this.
Nowik35
Nowik35
So the engine is in, I think everything is good, when I push on the bronco the crank shaft turns when in gear. Time to start connecting everything. Next milestone gas tanks! Look at my advance rig to lift the rear tank into position as I bolt it on. I have to say seeing the filler neck installed into the quarter panel with the cap on looks so nice!!!
https://flic.kr/p/2oXYNws https://flic.kr/p/2oY54qD
A functioning filler cap is definitely a mile stone!
What’s that big U-bolt clamp thingy doing on your leaf spring?
If it’s just there to keep the individual leaves from fanning out, they make much smaller, less obtrusive clamps to do that.
At the very least, if you’re going to keep that thing there, cut the extra threads short.
Unless it’s just there waiting for an additional spring pack in the form of overload leaves to be installed?
Nowik35
Nowik35
Yes I got an inexpensive universal set just to keep the leaves from fanning out. When I first brought the eb home there was a set on them but beyond salvation so I wanted to get something very inexpensive to replace the old u clamps. Do I even need them?
You might.
Only driving it around will tell the tale.
It’s such a common leaf spring issue that they build them that way with clamps on certain leaves.
Aftermarket leaf packs like ours have more than the factory because we expect the springs to be flexed a lot when taking off road.
One way to make sure that fanning is at least reduced, would be to make sure that center pin bolt is tight, and the u-bolts are torqued properly.
When the leaves do fan out, simply pushing them back, or hitting them back in with a hammer cures it until the next time they fan out.
Rinse, repeat…
Hence the clamps.
If you have a spring pack that is particularly prone to fanning, they will usually break the small cheap clamps that most stores sell.
The ones that are meant to just be bent over by hand are good for a pack that does not have a major fanning problem.
But if the springs really want to go, they will eventually break the small clamps.
The ones you have are going to be super strong. Luckily, they’re easy to remove and reinstall, so you could take them off and see how bad your springs act.
If you’re chasing an errand leaf every few weeks, put it back on and leave it
sprdv1
REBEL
one more thing off the list
sprdv1
REBEL
You might.
Rinse, repeat…
Hence the clamps.
absolutely...
Nowik35
Nowik35
So another update. I feel like I don't have many "large" milestones left. It seems I put a couple hours a week and things slowly are coming together and before I notice I did like 10 things. Any ways since my last update
1. Fully finished installing main gas tank
2. Fully installed aux tank and neck
3. Plumbed in the fuel lines to the fuel pump and installed an electric switch valve.
4. Installed parking brake. ( only to find out stock cable doesn't fit 2.5 in lift) 🤦 but got the extended one now everything works well
5. Installed all main brake lines, MC, ( still need to bleed the whole system)
6. Steering column installed. The three on the tree.... Can't wait to use it but what a pain in the ass to get everything to work. Had to weld repair my lever tube, lever housing, also had to purchase new links from column to transmission. Bc I cut through my old ones during dissembly like an idiot. Anyways got new ones installed but had to remove them like 4 times and slightly bent them to fit just right and not hit the bell housing during shifting.
7. Clutch fully installed, everything works well.
8. Throttle cable installed. Went with a universal replacement. Took way longer then it should have.
9. Just purchased all new dash levers and bezels. And excited to install them.
Just purchased the painless wire kit so time to teach my self how to be an electrician.
I think I can see the end of the tunnel!!!!
Some pictures of progress
https://flic.kr/p/2p7kiCr https://flic.kr/p/2p7kDWy https://flic.kr/p/2p7j9je https://flic.kr/p/2p7jMRp
Nowik35
Nowik35
Man I'm not so good updating my build thread. I would say I'm on home stretch, but then again what does "done" actually mean??? My wife, kids, friends keep asking when will I be done with the bronco. I often struggle to answer because what does that mean, when will it drive? When will I register it? When will I put the final screw in the trim?
Anyways since my last update I've been busy. I wired the whole bronco. Everything works well now but not without my frustration of problem solving little issues during the process.
All the dash components are in, retro radio installed. I also made up some custom rear speakers to give my bronco a little more entertainment then just the one little dinky speaker in the front. Lately I installed some under dash lights to really highlight the interior. Looks nice.
This month my goal is to finish the door windows and all the windows. Just did the vent window. I ended up restoring my original ones bc for some reason new vent window are a million dollars.
Next seats and in the spring going to try and start my engine.
Here are some pics of update
https://flic.kr/p/2pzfpJC https://flic.kr/p/2pzfpGy https://flic.kr/p/2pzg9Et https://flic.kr/p/2pzfpFg
Torkman66
New Braunfels, Tx
VERY nice work! Its never really done. That's part of the joy right? Always some little tweek or update owning a classic. But man is that a nice Bronco!
Nowik35
Nowik35
For every step forward always a step back. Another great milestone. I just finished installing all new brake lines AGAIN. But just bled the system and all the wheels work great, no leaks. Success!! I said again bc this is my second set of lines, why because first time I didn't know you had to double flare the ends.i only single flared so every fitting leaked. Well I learned the hard way but now I have a functional brake system! Just as I'm ready to finally turn my attention to prepping the engine to start. I did a once over through all the electrical and now my e flashers stay solid. So back to diagnostics through all my electrical again to find the short....ugh
Oh ya I also installed all the windows, windshield, windshield wipers, chrome bumpers, and built all the guts of the doors. Also installed all the weather seals. Door close a little tough, either that's how these broncos closed back in the day or my excellent skills. Either way they look good and work.
Oh ya and ropeing in the glass is not fun. Some updates
https://flic.kr/p/2pCVrbX https://flic.kr/p/2pCNH9Q
Torkman66
New Braunfels, Tx
Really nice! That is a beautiful Bronco. The build is the joy in this hobby. We learn so much along the way. But once you figure something out that was an issue, feels great to make it right. Think about how much you will love your ride after it’s done. All your work! Great job.
Nowik35
Nowik35
After 6 years , the day I brought her home on a flat bed with buckets of parts and rust, I often thought I'd never get to today. I started her tonight!!!!!!!! This is the original engine that hasn't been on in over 20+ years, I choose to rebuild it my self and not upgrade. I mean the proof is in this thread but I touched every bolt on this car to bring it to today. Amazing feeling to hear it run. I rolled it out with my son, told the family to stand back and I turned it on. Runs great and to top it all off, I backed it back into the garage with it's own bronco power!! Big millstone!!!!
Speedrdr
Legend in my own mind
Paris, MS
Sweet ride. I am certainly glad that you never gave up on the restoration. This proves that I will be able to post up pics of a completed EB.
Randy
