brewchief
- Feb 11, 2007
- 872
I'm planning a C-6/205 swap in place of my currant np435/dana20 and have a few questions, yes I did try to search but terms like C-6 end up with no results since they are two short or something.
Block plate? same for C-6 as C-4 or is it different? If different is it the same as any other trans?
Long or short adapter? I have both and can swap tailshaft in trans when it gets rebuilt, short looks like there will be some driveshaft interference with the oil pan on the trans, long will lose even more rear shaft length.
Body lift? I have 2" right now but wouldn't mind dropping it down to 1" if it will all fit.
I know I need a 50oz C-6 flexplate and starter, I have a crossmember that should work since it was used for this swap previously, trans cooler is handled as is shifter, what else am I missing?
I know both driveshafts will need rework, if I have to go to a high angle CV shaft in the rear it's not a big surprise.
Should be ready to pull things apart in the next couple weeks so I'm trying to get a plan going so I have most of what I need to at least mock things up.
