C4 fluid
gambling209
I am in the process of totally rebuilding my C4 transmission. I would like to cut down on the different kinds of transmission fluid I have to buy. Can I run Mercon V in this transmission? Or is there a better fluid to run. Most of my other vehicles take mercon v.
JohnJohn
Richmond
That is what I am running in my rebuild C4. The Performance Automatic shop that rebuilt my trans also recommended to us V.
While you can run Mercon in a trans designed for Type-F like your C4 was originally, I would at least change the clutches to a friction material that is expected to see Mercon instead.
I think that's really the only difference between the transmissions that use the different fluids anyway. And when you get a performance rebuild, the builder will usually specify which fluid based on which clutch packs they used.
At least that's how I understand the process.
Since you're in the process of a full rebuild anyway (which would normally include clutches, correct?) then now's the perfect time.
Look at the instructions in the rebuild kit. What fluid does it specify?
With many (but not all) of the rebuild kits you can run Merc V. Depends on if the rebuild kit is engineered for it or not.
There is no universal internet answer, it is a kit specific answer.
68ford
Pretty sure all rebuild kits for c4s and c6s that are newer than 20 yrs are supposed to have dextron/mercon NOT type F. Typically dextron/mercon 3. Mercon 4 and 5 are backwards compatible designed to be better and take place of lower numered fluids. So mercon 5/V is fine.
If your trans IS meant to have type F, you really need type F is what I have always been told.
Viperwolf1
electron whisperer
Standard clutch sets for C4s are old school, paper clutches that work well with Type F fluid. You can find some exotic clutches but those are marketed toward racing applications and they generally don't work all that well in normal street use. I bet at least 95% of all C4s on the road are still using paper clutches.
gambling209
gambling209
I will look and see what the kit recommend. It's a Transtar kit and I don't remember there being in any paperwork with it. Could be mistaken I will let you know
blubuckaroo
Grease Monkey
Ridgefield WA
When I had last rebuild on the C4, the rebuilder said to use only Dextron. I had 65K miles on that rebuild, and as far as I know, the buyer is still using it.
68ford
You can almost guarantee if it was rebuilt newer than 1990 it takes mercon, NOT type F.
gambling209
gambling209
Fluid
So I called TranStar, because there was no paperwork with the kit. They said to use Mercon dextron. The clutches are Borg Warner clutches. The ones that look kind of yellow looking. Now I just need to figure out where to buy a new Torrington bearing for this transmission
Local Boy
Mililani, Hawaii
