C4 to a 1983 351windsor
soala70
Putting a 351 Windsor in 76 bronco. Anyone have experience with this? I have read so many post on here I am completely lost.
bronconut73
Duff has a nice listing for what is needed.
It really ain't much.
If you keep the original 351W accessories you won't need the adapters to run your 302 accessories.
A 1" body lift will help a little but not absolutely necessary.
Most of the headers will fit both 302 and a 351W in an eb.
It's basically a bolt in if it's replacing a small block Ford 289/302.
But check Duff's out.
bronconut73
Found this in an old Duff catalog.
bronconut73
Basically a bolt in Bud.
Very little mods.
Very worthwhile.
Read that Duff stuff in the photos.
You'll need the oil pan unless the one you have on the Windsor is already a rear sump.
That may be all you need.
It's easy Bud.
Jump in.
S
soala70
What I am confused on do I use flex plate and harmonic balancer off 302 or 351w (351 had a c6 bolted to it
Viperwolf1
electron whisperer
Do not use a C6 flexplate. The offset is wrong. You can use the balancer and flexplate from your original 302 if it's older than 1981.
S
soala70
had a set back started back on project
can I use harmonic balancer off 351w 28oz and serptine pulley from wildhorse
and a 28oz 164 tooth flex plate for a c4 from wildhorse?
The bolt pattern on the damper has to match the pulleys. 3 or 4 bolt
28 oz-in 164 tooth flexplate is correct. If that will bolt to the existing torque convertor is debatable, and probably not going to happen. If you have the small bolt circle torque convertor, you either have to re-use your existing flexplate or get a large bolt circle torque convertor.
cs_88
My biggest modification when installing my 351W was going from a 3" tall air filter to a 2"...
Not really, but as others have said it's pretty straight forward, gets a little tight under a stock hood and the exhaust may need some rework.
