Mill KNOB
I am trying to decide on which out of the two 1 Barrel carbs do I have rebuilt by Guaranteed Carbs.
Option one: The original that came on the truck from factory which has not been on the bronco since the early 80's. I pulled it out of the box that the original owner gave me. It has stamped on it HOLLEY? Did Ford put Holley on there 170 6 Cyl? The original had someone cut the bracket off were the accelerator cable hooks to it (I discuss that in the 2nd option). I didn't know they went with Holly, I have always seen Motorcraft or Autolite carbs.
Option Two: The carb that was on the Bronco that seem to perform good. Just needs to be rebuilt. It is a Motorcraft ( D0PF L A0A5). It has the plate welded to it on the side for the accelerator cable to hook to. It works, It don't look all that bad.
I am wanting to go back with a good all Original carb. The people at Guaranteed Carbs informed me they might be able to fix the side plate that was cut off the Holley and place a new back on.
Fill me in on the Holly carb and if Ford did place it on there 6 Cyl and if so your experiences with them. I also would like to know which out of the two you would perfer? This is my first 6 Cyl and I no nothing about the 1 Barrel set up.
Also, post some pic up of your carbs next to the area that the accelerator cable hooks up to make sure I don't have somersetting crazy going on.
