Cam Dowel Pin
Waverous
Aurora, CO
Taking my fuel pump eccentric off for an Explorer Serp conversion and I started to wonder about the cam dowel pin - is it too deep? Should I be concerned? Or am I over-reacting, cause I never do that, Oh My God, I Never Over-react!;D
Not overthinking at all. A good call I would say.
I can't verify 100% but I'm pretty sure that you do in fact have to shave it down some for clearance under the new cover.
Someone will let you know, but at a guess I would say that as long as it engages the gear without sticking proud of it, you'd be good to go.
What about the gears and chain themselves? Are they from the engine, or are they Explorer spec?
Not sure there's a difference, but if we're going to overthink things, why not go all out!
Waverous
Waverous
Aurora, CO
HA! Love it!
Anyway, the gears are from the 302 in the Bronco
EricLar80
The pin is in shear. Just made sure you always have the pin crossing between the cam and overlapping the gear and you are fine. Maybe 1/2 the pin diameter or more of overlap would be fine.
There is a long and a short dowel pin. Typically we are dealing with a long pin in a short hole. This may be a short pin in a long hole.
Waverous
Waverous
Aurora, CO
There is a great joke in there, but I am going to leave the low fruit hanging! Thanks for the response I agree (didn't even think about the pin being a short pin) with your assumption - makes total sense!
