Thanks go to Dusty at West Coast Broncos for sponsoring another ClassicBroncos giveaway!
Prize: Modular Horizontal Tab Mounts from FourTreks
Description: (From the West Coast Broncos site) Looking for a place to mount your whip antenna, cb antenna, flood light or driving light? Use our Horizontal Mount Tab to mount it on your roll cage, roof rack or bumper. Designed to work on a horizontal tube of your choice. This mount includes our standard billet aluminum Clamp Ring, a stainless steel threaded Horizontal Tab and all the necessary stainless steel hardware. The Tab can be ordered with two different through hole diameters. One option will accept standard 1/2" SO-239 antenna mount stud used with CB antennas, standard CB coax cables and ham radio antennas. The other option can be used to mount various spot or flood lites and whip antennas to your vehicle's tubing. Choose your application from the pull down menus. CB antenna, second mount and flood light shown not included. Stainless steel hardware is included. Available for a wide range of tubing diameter applications. See the pull down menu for our extensive sizing options.
All FourTreks modular mounting components are precision-machined from T-6061 aluminum for light weight yet high strength. The system is made up of two basic components; a clamp ring and an adapter. The clamp ring is precisely machined to clamp around your exact roll bar diameter: 1", 1-1/8", 1-1/4", 1-1/2”, 1-5/8”, 1-3/4”, 1-7/8”, 2” and 2-1/4”. The two-piece clamp ring bolts around your roll bar using stainless steel hardware. The second component is the adapter (to mount the ji-lift jack, shovel, flashlight, etc). Because the system is modular, all components can be interchanged, making it easy to switch between different tubing sizes without having to buy a new complete kit.
West Coast Broncos is also running a sale on all FourTreks products. See their post in the Vendor Forum for more details. http://classicbroncos.com/forums/showthread.php?t=123158
The Rules:
Who can enter? - This giveaway will open to forum Contributors only as a way of saying thanks for helping support the site.
How do you enter? - Please post in this thread if you want to be in the drawing. That way only those that actually need the parts will be picked.
Deadline? - The winner will be drawn randomly after Sat Aug 16th (all entries in by 8:00 PM)
Good luck!
And thanks again to West Coast Broncos!
The Rules:
Good luck!
